MMM V3 case update ??
CRTIM
MMM V3 case update ?? - 11.06.2008, 04:50 AM
received my V3 case upgrade today....and the foam that is inside the bottom of the V2 case isn't on the new V3 case....with more space between the case and circuit board do you think the foam is still needed ??...should i find some sticky foam to put inside the V3 ??...thanks for the help
