I just purchased a Revo for a BL conversion and the shocks need some love...and was wondering what the bashers are using for shock oil as well as what spring set up you are using. The truck has the p2 rockers on it already. I plan on adding titanium turnbuckles and titanium pins and a few odds and ends.
I have this mount...
http://www.rc-monster.com/proddetail...vomount&cat=33 and did a test fit w/my 9xl just for kicks, I will be getting a 70 series Medusa later to run in it, and noticed that once the pinion was lined up w/the spur, the shaft of the motor only was 3/4 the way thru the pinion. That being said, will I need long shank pinions for this set up? Again, I will be using the Medusa for this truck, NOT the 9xl.
Thanks for the help
Brian
