MMM Combo 2200 a lot of cogging... -
01.29.2009, 10:06 AM
Today I received my MMM Combo 2200 and put it in my Losi 8ight-e (4s) (16th pinion)I have a lot of cogging instead of a smooth start ....
I am also using a MMM V3 and a NEU 1515/1/Y in my Emaxx on 5s and it is very smooth.
Are there different MMM V3s available ? The older one beeps 5s times on startup indicating that I am using a 5s lipo setup. The new one in the combo doesn´t...
I like chocolate milk
01.29.2009, 11:17 AM
If it doesn't beep 5 times, then the auto-lipo setting is probably not set correctly. It might be cogging because the LVC is kicking in. Take a look at it with the castle link and see.
01.29.2009, 12:03 PM
Ok, I turned on auto-lipo ... this was my fault but the cogging still remains... It might be a problem with the very strong magnets inside the motor.
01.29.2009, 12:25 PM
It should not be cogging, there is a problem somewhere. Make sure all you connection are good with good solder joints on the bullets.
01.29.2009, 12:52 PM
There has been one other report of a bad solder joint - worth checking
01.29.2009, 01:01 PM
I've seen bad solder joints from CC on more than one occasion... Fortunately they weren't on any of my CC items, but a buddy of mine has had a MM 5700 and MMM 2200 combo each with a single bad solder joint that produced extraneous cogging.
01.29.2009, 01:08 PM
Realistically, that's not really a reason for cogging. It's more likely you have a bad connection somewhere.
01.29.2009, 03:12 PM
Solder joints are fine ....
01.29.2009, 05:28 PM
You have newest firmware in it? What lipos are you running, C rate?
01.29.2009, 05:34 PM
I am using Kokam H5 30 C 5000mAh lipos .
Yes I have the newest firmware 1.2
01.29.2009, 05:57 PM
Very hard to say then, Lipos sounds ok. Have you tried different setting for the controller? I would try reset all the setting to default and try then. But that just me, prolly wouldn't help anything.
Here's few thing that could cause cogging: bad solder joint, bad lipos, gearing, binding in drivetrain, (too long wires?), escs settings
01.29.2009, 05:58 PM
If this is truly cogging, I would think it was a connection or soldering issue. Since you say they are ok, we'll assume they are. And gearing sounds ok, although 5s on a 2200 kv motor geared with a 16T pinion is gonna be fast.
Might seem to be a PITA, but you could take the MMM from your maxx and try it in the 8ight-e. If it still coggs, put the 8eight-e MMM back in and try the Neu 1515/1y from the maxx. Just trying to isolate the problem component.
Sometimes, a glitchy radio can seem like cogging. Try plugging a servo in the throttle port and see how it acts. Obviously, it should turn smoothly. Even if it does, ESCs tend to be more sensitive than servos. And/or try the radio setup from your maxx.
01.29.2009, 07:34 PM
Try increasing start power on the MMM
01.29.2009, 11:31 PM
+1 this is a tell tail way to find out. it could be a bad solder joint inside the motor? where the wires meet the windings.
01.30.2009, 03:02 AM
Holy out of focus picture batman. I think I can see something there but I'm not sure.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
