Motor for 4s -
01.30.2009, 12:57 AM
Hey guys in my X1CR I have a MMM V3 speedy and a Medusa 36-60-2000V2-5 on 4s (2 * 2s) Reedy Lipos, with the 15t pinion the motor gets to 125 tops and Battery / ESC don't even get warm, but it feels like it's lacking top speed wise.
What are my options (our 1/8 electric class is expected to be restricted to 4s lipo)
01.30.2009, 01:56 AM
Hi,
I have the same buggy with 4S PQ 6000mah lipo MMM & I'm using a Neu 1512 2600KV geared 13/48. Pretty fast & competitive. In fact, managed the fastest single lap at my local track ever in a field full of nitros at a race recently.
The setup I'm running also made the 20minutes main under hot & humid conditions of the tropics. Was running in third until a mechanical failure (bolt holding the ackerman went MIA, effectively losing steering to one of the front wheel) put me in 6th place in the A main.
Regards,
Joe Ling
Hyper 9e Medusa 4S, Savage 5S MMM 8XL, Jammin' 4S Neu MMM, X2 Ninja JX, X2 MMM 5S Neu, E REVO Medusa 6S
01.30.2009, 02:33 AM
The best way to speed it up would be to go up to 5s, that alone will speed it up quite a bit.
01.30.2009, 02:52 AM
As stated in my opening post, we are restricted to 4s Lipo
01.30.2009, 02:57 AM
Ahh, must've overlooked the bottom part.
The 2000KV 60mm is the highest KV you can get in the 60mm, you'd have to go up to a 70mm for higher. If you can get your hands on a CC 2650 that would probably be just right.
Supermaxx
01.30.2009, 03:23 AM
Gear it up with a 16T pinion since your ESC/batt temps are barely warm like you said. It might even drop your motor temp.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
01.31.2009, 10:34 PM
Took it out last night, pig of a day, 7pm and temp was still 92f gave it a good 15 minute bash on lawn, hard stops, jumps, full throttle runs etc, ESC and Batteries came off arond 100-110 Motor peaked at 129 according to the temp loop on the can.
01.31.2009, 11:19 PM
Those are good temps. considering the temps. out side and running on grass, etc..
KillaHurtz
02.01.2009, 08:44 AM
I would just gearup 1st. You have plenty of headroom to load up the motor. I know on my 50mm in my Crt.5, it was a bit drowsy until I geared up enough, now its a fraking monster. Just keep track of lap times to see what works.
02.03.2009, 09:31 PM
I run a NEU 1512-2d or 2550kv motor on 4s geared 12/46 with a MM esc in my X1CR .
02.03.2009, 11:28 PM
I'm finding that the 2550-2600 kv motors people are gearing around 12/13t and it seems my current gearing is pretty right with the 16, even in these 100+ degree days I can go for a bash without any thermalling dramas :)
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
