Revo Hot Clutch bell
YogyBrushless
Question Revo Hot Clutch bell - 03.11.2009, 04:39 PM
i ran my revo with my mamba combo (2200) on 5s for the 1st time today i only ran it for 2-3 mins but the clutch bell got to 110f+ and i think it broke loose my thread lock
what can i do to reduce the heat and drag, punch control is already at 100% and i have a good throttle curve, timing is low . i thought i should remove the curve and have the throtle in a straight line cause the clutch bell will doing its job what do u think guys? and should i leave the clutch shoes in the leading position as tekno converted?
anyhelp would be good
Thanks
__________________________________
Must Find Cash For RC
Matthew_Armeni
Matthew_Armeni's Avatar
03.11.2009, 05:46 PM
Hi,
The clutch will operate between 120-170 degrees with zero problems, 110 is very low and won't cause any problems with your setscrew. Set your throttle curve to linear and reduce your punch control. Keep the shoes in the leading position, trailing will only increase heat.
  Send a message via AIM to Matthew_Armeni
js058515
Thank You Brushless Gods!
js058515's Avatar
03.11.2009, 08:27 PM
110 is really cool.......my 2 shoe clutch operates around 150 plus. I have never had a problem because of the heat either. Like Matthew said, it's normal operating temperature.
Losi 8B 1.0, Tekno V3, Direct-Drive, 13/48, RX8, T8 1400kv
Losi 8B 1.5, Tekno V3 w/clutch (3-shoe), 14/48, MMM, Neu 1512 2Y
Losi 8T 2.0, Tekno V3 w/clutch (3-shoe), 14/48, MMM, T8 1550kv
YogyBrushless
03.12.2009, 06:35 AM
ok guys got it, i will also replace the clutch shoes with new ones (these been on for a while with nitro) .
how punch control u think i should have ?
YogyBrushless
03.15.2009, 05:11 AM
anyone ?
George16
Supermaxx
George16's Avatar
03.15.2009, 05:17 AM
Experiment with it. Try 50% first and see if you like it or not and then go from there.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
YogyBrushless
03.16.2009, 03:10 AM
cool thanks
