Brushless E-revo power stats
NoControl
NoControl's Avatar
Brushless E-revo power stats - 07.02.2009, 11:58 AM
With Jalodo56 making a post in Brushless about eagle tree and asking if the 100A logger is sufficent. I decided to dig up the book on my Novak sentry pro Logger, and found that it to only supports upto 100A, looked back threw some previous logs I had made I noticed that the logger would read upto 105A and since I mostly only have a revo to test it on, and with CC suggesting that people use top end batterys I decided to start making recordings for Current vs voltage, and current vs throttle using my e-revo with MMM 2200 and the only lipos I have Zippy 11.1v 3s 5kmAH 20c.
I was going to try different gearing and try 6s vs 3s an was hoping to get some other testing but I only made it threw the 1st test which was:
E-revo
24/54
2x 3s Zippy 5k's in series
Badlands on Maximizer beadlocks
MMM V3 2200KV
settings:
lipo cutoff: 3.3v
brake 10%
drag brake 30%
punch 30%
reverse 30%
timing 10
start power low
slow throttle curve
speed run up and down my street to get differnet points on the throttle to show peaks and lows, only managed a few passes before I flipped the truck and my crappy solder job on the current sensor broke, but I still managed to get about 1min 50secs of run time and was able to cover a nice spectrum of graph points.
current vs voltage
current vs throttle
I'll post more graphs after I fix the cable.
E-revo MMM 2200 6s zippy 50MPH of pure fun and parts destroying powa!
Futaba 3pk more controller then anyone person needs
TC5 top speed drifter 21mph on crappacks and 40 on calc
