Havok Berg Build...
Havok Berg Build... - 04.07.2009, 04:17 PM
The shopping list!
Kamakasi Delrin High Clearance links (Front or Rear) : Black
Kamakasi Delrin High Clearance Tie Rod : Black
Kamakasi Delrin Rear Axle Tray : Black
Kamakasi dig tray
JPC HaVoc Chassis
JPC 2in x 2in Skid for HaVoc / HellStrom
JPC Delrin Chassis Brace
Holmes Dig Switches
Amain RRP1013 - Robinson Racing 48P Pinion Gear (13T)
Amain NWA-FR-11 - NewAge Servo Plate Upper Clamp
Amain NWA-FR-12 - NewAge Servo Plate Bottom Clamp
Amain NWA-FR-14 - NewAge Servo Mount
Amain NWA-AXL-SET - NewAge 2 Complete Custom 2.2 Crawler Axle Set
Amain RRP1012 - Robinson Racing 48P Pinion Gear (12T)
Amain NWA-FR-13 - NewAge Servo Plate
Amain AXIA1348 - Axial 6x6mm Spacer (Blue) (6)
Amain SPTSTA30881R - ST Racing Concepts Aluminum Rear Steer Conversion Links (Red)
Amain OFN28008 - OFNA Front Bottom Arm, (2)
Tower LXWVB1 Hot Bodies HB Rover Tire White Rock Crawler (2)
Tower Deans 2 pair
Tower LXHGB7 Traxxas Rod Ends w/Hollow Balls Large Revo (12)
Tower LXWMN2 Lunsford Racing Titanium Rock Grinder Link 4x55mmx3/16Tower LXLYV3 Integy Matrix Pro Lathe Motor 45T Single
Tower LXTVY1 Pro-Line 2.2" Eight Shooter Bead-Loc Black REAR
Tower L5WMM803 Lunsford Racing Titanium Servo Link AX10
CJL HS7955TG
CJL MM / 6v BEC
CJL Revo Red turbuckles
CJL 1200 2s Lipo
RCC Telfon skids
04.07.2009, 04:43 PM
WOW, quite the list! Look forward to seeing it done.
rchippie
rchippie's Avatar
04.07.2009, 05:12 PM
The shopping list!
Chris i think you have the wrong pinions. The berg axels use metric gears. Also you have a 12t & 13t pinon . Why the different gears ?.
REAL MEN RUN BRUSHLESS
04.07.2009, 05:38 PM
Balls they call it metric 48p but it is 0.6
I believe that this what I need Metric .6 Module Steel Alloy Pinions
1112 Metric Steel Alloy 48 Pitch Pinion 12 Teeth $3.50
1113 Metric Steel Alloy 48 Pitch Pinion 13 Teeth $3.50
The aim of the different pinions is to overdrive the front slightly which helps stop the rear pulling the front over...
rchippie
rchippie's Avatar
04.07.2009, 07:02 PM
I guess you got the right ones according to the robinson site . The part #'s you listed are the metric ones .
http://www.robinsonracing.com/catalo...on.html#metric
I went for the MAYHEM wheels because they offer a berg offset . so the truck is not to wide .
04.07.2009, 05:40 PM
Need some help with wheels - I'm torn:
- Proline Epic Rears $40
- Proline 8shooter $40
- Eritex $75
- Mayham comps $110
I'm kind of loathed at the moment to pitch up the extra $70 but don't want to waste $40 on wrong wheels either! LOL
HELP
RCShocker
RC Monster
04.08.2009, 06:35 PM
- Eritex $75
- Mayham comps $110
I see several guys running Epic's but the wheels can strip fairly easy if you are not careful. Or possibly plan to test alot of foams and/or tires.
The offset is a fairly attractive selling point for the 8-Shooters. They are pretty good wheels. They were the first set I bought.
I like my Eritex Comp Heavy's very much. I run Rover's white on them.
I had a set of Mayhem wheels that were very nice but not the offset I was looking for. I will own another set of Mayhem wheels sooner or later.
The 1" DNA wheels are nice wheels too. I run a set of Assassin's. I'm in the process of mounting up some Chizzy's to them as we speak.
Day late and a dollar short, huh?
You'll like the DNA wheels. The Berg offset is nice & narrow.
04.07.2009, 09:28 PM
Update picked up the Tekin 35T's and DNA Stalkers berg offset
rchippie
rchippie's Avatar
04.07.2009, 09:31 PM
Those are good choices. Are the tekin's hand or machine wound ?. I went with the cheap integy 45t motors for now .
04.07.2009, 09:37 PM
Looks like machine wound but the only 35t's in stock on the planet - an expensive day...
rchippie
rchippie's Avatar
04.07.2009, 09:42 PM
It sure sounds like you spent alot .
04.07.2009, 09:48 PM
Well sale of a brushless losi 8 and a converted crt .5 covered it - just
rchippie
rchippie's Avatar
04.07.2009, 10:11 PM
I sold some stuff as well to build my KK 4.0 berg .
04.07.2009, 10:19 PM
I kept the AX10 for my son...
rchippie
rchippie's Avatar
04.07.2009, 10:35 PM
Thats cool that each of you will have a truck to use .
