Gearing E-maxx with MMM combo
Klausen
Brushless G-maxx
Klausen's Avatar
Gearing E-maxx with MMM combo - 03.28.2009, 01:37 AM
What gearing would you guys suggest for a 3906 E-maxx with the MMM 2200 combo. I am currently running a HV6,5 with 70/12 gearing.
If the postal service are on time, I should recieve my MMM combo today, and I see that it comes with a 18t. pinion. Should that be ok with the 70t spur gear?
I am running on 2 x 7,4 v. Maxamps 6000 mah. lipos.
q8-maxx
E-Maxx Lover
q8-maxx's Avatar
03.28.2009, 04:40 AM
no it will be too slow 28-30 mph. i use 24/64 for my 3096 tranny but i run medusa 70/2300 :) you will get 42-44 mph with cool run
MMM v1 zippy 2x3s 5000mah neu 1y 1/8 diff's
MMM v3 Rc-monster 2x2s 5200mah-HC medusa 36-70-2300kv
Pic's - video - youtube video's
Klausen
Brushless G-maxx
Klausen's Avatar
03.28.2009, 08:01 AM
I am using the RRR slipper, and their smallest spurgear is 66 tooth. Should I just go with a 26 pinion then?
q8-maxx
E-Maxx Lover
q8-maxx's Avatar
03.28.2009, 09:10 AM
i don't know if 26 will be hard on motor or not. and maybe you will find a problem with mesh spur and pinion.
if you have 6s setup you can use 18/66 and get 46mph without worry about temp.
and you can convert your tranny to gorilla single speed with revo input then you can use the new e-maxx spur style just like me.
Klausen
Brushless G-maxx
Klausen's Avatar
03.28.2009, 11:12 AM
The tranny is Gorilla single speed ( you can see full set-up in the link in my signature).
Do you have a link to the Revo input?
jayjay283
jayjay283's Avatar
03.28.2009, 12:46 PM
If you run the set up 66 rrp spur/22 pinion with the mashers, 2200kv on 4s you will be cruising a nice 43.5, want faster just up to 5s (54mph) and 6s (65mph)...
http://scriptasylum.com/rc_speed/_top_speed.html
q8-maxx
E-Maxx Lover
q8-maxx's Avatar
03.28.2009, 12:53 PM
ok its very easy if you have gorilla single speed.
here is the revo input http://www3.towerhobbies.com/cgi-bin...?&I=LXHGE1&P=7
and you must have 3905 slipper
http://www3.towerhobbies.com/cgi-bin...?&I=LXHGC5&P=Z
http://www3.towerhobbies.com/cgi-bin...?&I=LXTKK8&P=Z
http://www3.towerhobbies.com/cgi-bin...?&I=LXTKM3&P=Z 62T
http://www3.towerhobbies.com/cgi-bin...&I=LXKLZ9&P=ML 58T
http://www3.towerhobbies.com/cgi-bin...?&I=LXVCX9&P=7 24T
Klausen
Brushless G-maxx
Klausen's Avatar
04.01.2009, 02:33 AM
Thanks for the replies. I will pick the system up at the postal office today, and start out with the 70 t RR spur I have and the 18 t pinion that is included. At the same time I will order a 66 RR spur and a few pinions, so I can try out what works.
