Originally Posted by suicideneil
At 18/68 you wont see much difference, but you can gear that setup to top out at around ~60mph or so. Granted, the V-twin can do the same, but the MMM is lighter and simpler, and much more tweakable.
The MMM system is more demanding on the batts for sure, but, top end systems require top end components really- the better the batts the higher you can gear for and still stay cool.
If you are trying to run the same speed either system will draw the same from the batteries. I would actually say the MMM/combo is more efficient than the vxl so it should be slightly easier on the batts.
Vehicle speed, tire weight and drag will determine the wattage requirements for the truck, if the motor efficiency is the same the amp draw from the lipos will be the same too.
The more demanding comment may refer to the fact that the MMM motor can produce more torque than the twin vxl setup.... So the systems may not be equal.
