Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
40 series vs original
$w!ft
40 series vs original - 02.01.2006, 08:09 PM
Hey there!
I just have a question for you... Whats the difference between 40 series tires and std tires? Obiviously i can see that they seems to be wider and set closer to the wheel. Do they make you handle better? Are they lighter?
I cant choose between a set of normal bowties or 40 series...
Cheers!
Batfish
Batfish's Avatar
02.01.2006, 08:33 PM
You've got the idea with your thoughts. Less sidewall generally means the tire won't "roll" so much in corners, which then provides more side bite. The advantages of 40 series tires are more apparent for racing conditions.
Joe
