Current draw of a 3511KV 5407L with no load on 2s or 3s lipo? Need some help here.
littlegiant
Current draw of a 3511KV 5407L with no load on 2s or 3s lipo? Need some help here. - 07.18.2009, 08:40 AM
I suspect that my feigao has partiallly demagnetised. Right now i am having a current draw of 6A unloaded on 2S lipo. Is this normal?
hemiblas
hemiblas's Avatar
07.18.2009, 01:13 PM
That sounds pretty high. I will look later on and I think I have one of those laying around somewhere and a wattmeter. I will try to give a comparison, but usually its only 1 or 2 amps from what I have seen.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
07.18.2009, 01:32 PM
My 7XL will draw 6.5 amps no load on 6s lipo... so it could be right. Maybe check Fiegao website for idle currents?
littlegiant
07.19.2009, 12:00 AM
Hi, thanks alot for the info. I've tried searching on feigao website but all I have found is the max current spec of the 540 motors.
zeropointbug
Z-Pinch racer
07.19.2009, 12:19 AM
No prod bob.
It's probably right... Fiegaos aren't exactly made with high quality control, so everyone's results may vary a bit.
littlegiant
07.19.2009, 12:28 AM
No prod bob.
I've tested the rest of my motors and found that motors with stator has a lower idle current. Motors without stator cores but have very strong magnets have higher idle current. Higher KV = higher idle current.
Well it all makes sense now. :D
All tested are 2 poles motors.
hemiblas
hemiblas's Avatar
07.19.2009, 04:42 PM
Sorry it took me so long. 3.4A on 2S, 5A on 3S.
littlegiant
07.20.2009, 12:33 PM
Ok that's a 5407L right?
I guess my feigao is working fine. Max current draw on a 1/10 buggy was 33A on 3S sounds ok right? Race track will be different I understand.
J57ltr
07.20.2009, 01:41 PM
So what is the test procedure for idle current?
Jeff
littlegiant
07.20.2009, 02:25 PM
Jeff
Hook the esc up to a wattmeter and apply full throttle. Check the amp reading.
The motor must be without any load (free load)
zeropointbug
Z-Pinch racer
07.20.2009, 02:27 PM
Well, it's a very complex and time consuming procedure, where you take any load off the motor and run the thing WOT and measure the currents using an eagletree or similar unit. Now, this is only for the non faint of heart and experienced RCist.
J57ltr
07.20.2009, 09:35 PM
Well I didn't know, I didn't think you were supposed to run them at full throttle without a load (though I have done it), and idle to me means low rpm.
Jeff
hemiblas
hemiblas's Avatar
07.20.2009, 08:23 PM
Woops, you know what, it an 8L purple feigao. Sorry about that. I can only read the 77A max sticker and the .0076 ohm on it which I think corresponds to an 8L motor. So a 7L would be higher than what I gave you. Ya I just hooked up my wattmeter and let it run full blast for a couple of seconds. I tried a couple times to be sure, but you dont want to run these things unloaded for too long.
33A peak on 3S sounds fine. In fact that might be a bit low. I'm assuming its a light buggy to get that number. But ya looks like it is ok.
littlegiant
07.21.2009, 12:11 AM
Hey thanks alot. 33A peak on 3S was tested on a low traction surface. Asphalt or grass will definitely result in a higher peak current.
hemiblas
hemiblas's Avatar
07.21.2009, 01:06 AM
Something I have learned about the feigao motors is they last forever as long as you cut the run short when they get to about 175 ish. Once they go over that and overheat, they become useless. So watch temps.
