Trouble calibrating mmm
bryan
bryan's Avatar
Trouble calibrating mmm - 08.15.2009, 02:44 PM
Trying to recalibrate my mmm after using castle link and it will recognize full throttle but not reverse red continues to blink. I have done this a ton of times before.i even tried changing end points on my transmitter"dx3s". Any suggestions. Oh yeah i just downloaded the firmware.
08.15.2009, 02:53 PM
Could be a firmware bug, try rolling back to the last version (Im still using the older versions as I dont believe in fixing things that run perfectly....).
08.15.2009, 03:05 PM
On your DX3s, not only do you have to make sure your endpoints are at 100%, but your brake travel is set to 100% as well. Also, adjust throttle trim to 0.
bryan
bryan's Avatar
08.15.2009, 03:48 PM
Good call there were some errors when i downloaded the new firmware. I reloaded and now programming is working fine.
