Motor upgrades for flux? Also question on wheel wideners
Slowkrawl
High-Voltage Fetish
Slowkrawl's Avatar
Motor upgrades for flux? Also question on wheel wideners - 10.11.2009, 06:29 PM
Hey guys, I am not really up to date or informed on the "big" brushless motors. I am tossing around the idea of a motor swap in the flux, mainly because it's bothering me that it's stock haha. The performance is awesome, but it's still stock! Is there a motor I could swap in? I don't want "bang for the buck" I want the best of the best, I basically just want to know what is out there? If anyone "in the know" could give me some insight that would be great.
Also, I was thinking about a set of wheel wideners but I have heard they just break more parts?
extended chassis is on the way, so I figure I might as well give it some lovin' while it's apart and cold outside. Thanks,
-Matt
Freezebyte
10.11.2009, 06:38 PM
Uh you really can't get much better then whats already in the Flux without spending ALOT more money. You could go with a novak sensored system to go with the next step I suppose
http://www.teamnovak.com/products/br...tem/index.html
No experience with wheel wideners though offset rims will give you extra control and stability.
Slowkrawl
High-Voltage Fetish
Slowkrawl's Avatar
10.11.2009, 07:03 PM
Hmm, might be tricky to find wheels I like with a decent offset.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
10.11.2009, 07:16 PM
Novak makes great products but it would be a turn in the opposite direction, The Flux is basically a Steve NEU designed Castle 2200kv motor with a different can/heat sink.
If your running 2s in series, a upgrade would be a Genuine NEU motor 1515 Y. I would suggest you spend you hard earned money on drive train upgrades and worry about another motor when you roast the one you have now.
Slowkrawl
High-Voltage Fetish
Slowkrawl's Avatar
10.11.2009, 07:27 PM
I run it on 6s, and you may have a valid point. I more or less just wanted to know what my options were, for future reference. I have the diffs set up to where they seem to be holding, and just installed the HD drive gear. I'd still like a little more speed, maybe because I'm an idiot?
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
10.11.2009, 08:14 PM
When it comes time for a new NEU, get a lower KV version. It'll run cooler and speed will be more than you'll ever need prior to flight.
rchippie
rchippie's Avatar
10.11.2009, 08:17 PM
Agreed the only possible upgrade might be a TRUE steve neu motor . But in my opinion most people could not tell the difference with out a eagle tree system .
REAL MEN RUN BRUSHLESS
Slowkrawl
High-Voltage Fetish
Slowkrawl's Avatar
10.11.2009, 08:47 PM
From what I understand the biggest difference is durability?
E-vil Maxx
10.11.2009, 09:40 PM
I would just leave it, but if you have too what about the new tekin rx8 seems like a nice combo.
danhfvcsd
10.13.2009, 06:06 PM
On the wheel widening thing - i am not sure exactly what you are after - but i have run RD Logics 23mm Hub Extensions that worked very well - i ran them with Big Joes and Proline Cheyennes - i was quite worried at first, but they are strong as, and hold up very well - even with alot of bung/awkward landings and cartwheels, they have been bullet proof in my truck, but have not heard of anyone else running them funnily enough.
10.13.2009, 06:29 PM
Ok, the 2200 is a 1515 size neu clone.
So the logical upgrade would be a 1521 motor. If you get a smooth can it will bolt right into the stock flux mounts. Nothing else will fit (unless it is the same diameter as a smooth can 15 series neu). I run a 1521 1y (1577kv) on 6s in my large trucks, and it does very well. Since you currently run 6s and a 2200 motor you would need to re-gear quite a bit if going to a lower kv motor. Not sure if you can change the gearing enough to run a 1600kv motor.
As far as going to a Novak system???? Freezebyte, you must be joking, or you are a huge dumbass... 1st the setup you linked is for 10th scale, and novak does not sell anything close to the power the flux/tork setup produces (maybe run 2 of their "8th" scale hv systems?)...
Wheel wideners are not a good idea, extra stress on wheel bearings will just cause continual failures in that area. Get some high qual bearings and use a different offset wheel if you want it to be wider. Not sure but someone makes wider arms, cvds, etc for the savvy.
danhfvcsd
10.13.2009, 06:41 PM
FLM makes wider arms that work very well also =) I havent had any problems with my wheel extensions or in that area.... yet - but i've had well over 6 months of hard use out of em...
Finnster
KillaHurtz
Finnster's Avatar
10.13.2009, 07:06 PM
Ext chassis, 1521, and even SavXL wideners, 40 series. I have a SavXL, and I have not had a bearing failure in over a yr of use. I just pulled them all out for cleaning & oil, and the OEM ones were still super smooth.
Basically that exactly what I got. :) Be careful as the weight does add up. Mine is a pork-u-pine, but it fookin rocks. Makes my Revo look actually 1/10th scale.
+2 to FB displaying extreme dumbassery. Novak 1/10 on a 1/8th FTL. We'll excuse this once, on acct you are in Montana and its getting quite cold and obviously impairing your judgment.
Freezebyte
10.13.2009, 09:50 PM
Least I can draw spiders with 8 legs
Finnster
KillaHurtz
Finnster's Avatar
10.13.2009, 10:17 PM
Ah.. I obviously never told you my tale of my seven legged spider. :)
It is a long but interesting tale. Aye, just a year ago:
Date: Wednesday 8 Oct 2008 12.19pm
To: Finnster
Subject: Overdue account
Dear Finn,
Our records indicate that your account is overdue by the amount of $233.95. If you have already made this payment please contact us within the next 7 days to confirm payment has been applied to your account and is no longer outstanding.
Yours sincerely, Jane Gilles
Date: Wednesday 8 Oct 2008 12.37pm
To: Jane Gilles
Subject: Re: Overdue account
Dear Jane,
I do not have any money so am sending you this drawing I did of a spider instead.
I value the drawing at $233.95 so trust that this settles the matter.
Regards, Finn
Date: Thursday 9 Oct 2008 10.07am
To: David Thorne
Dear Finn,
Thankyou for contacting us. Unfortunately we are unable to accept drawings as payment and your account remains in arrears of $233.95. Please contact us within the next 7 days to confirm payment has been applied to your account and is no longer outstanding.
Date: Thursday 9 Oct 2008 10.32am
To: Jane Gilles
Dear Jane,
Can I have my drawing of a spider back then please.
Regards, Finn.
Date: Thursday 9 Oct 2008 11.42am
To: Finnster
Subject: Re: Re: Overdue account
Dear Finn,
You emailed the drawing to me. Do you want me to email it back to you?
Date: Thursday 9 Oct 2008 11.56am
To: Jane Gilles
Subject: Re: Re: Re: Overdue account
Dear Jane,
Yes please.
Regards, Finn.
Date: Thursday 9 Oct 2008 12.14pm
To: Finnster
Subject: Re: Re: Re: Re: Overdue account
Attached <spider.gif>
Date: Friday 10 Oct 2008 09.22am
To: Jane Gilles
Subject: Whose spider is that?
Dear Jane,
Are you sure this drawing of a spider is the one I sent you? This spider only has seven legs and I do not feel I would have made such an elementary mistake when I drew it.
Regards, Finn.
Date: Friday 10 Oct 2008 11.03am
To: Finnster
Subject: Re: Whose spider is that?
Dear Finn,
Yes it is the same drawing. I copied and pasted it from the email you sent me on the 8th.
David your account is still overdue by the amount of $233.95.
Please make this payment as soon as possible.
Date: Friday 10 Oct 2008 11.05am
To: Jane Gilles
Subject: Automated Out of Office Response
Thankyou for contacting me.
I am currently away on leave, traveling through time and will be returning last week.
Regards, Finn.
Date: Friday 10 Oct 2008 11.08am
To: Jane Gilles
Subject: Re: Re: Whose spider is that?
Hello, I am back and have read through your emails and accept that despite missing a leg, that drawing of a spider may indeed be the one I sent you. I realise with hindsight that it is possible you rejected the drawing of a spider due to this obvious limb ommission but did not point it out in an effort to avoid hurting my feelings. As such, I am sending you a revised drawing with the correct number of legs as full payment for any amount outstanding. I trust this will bring the matter to a conclusion.
Regards, Finn.
Date: Monday 13 Oct 2008 2.51pm
To: Finnster
Subject: Re: Re: Re: Whose spider is that?
Dear David,
As I have stated, we do not accept drawings in lei of money for accounts outstanding.
We accept cheque, bank cheque, money order or cash. Please make a payment this week to avoid incurring any additional fees.
Date: Monday 13 Oct 2008 3.17pm
To: Jane Gilles
Subject: Re: Re: Re: Re: Whose spider is that?
I understand and will definitely make a payment this week if I remember. As you have not accepted my second drawing as payment, please return the drawing to me as soon as possible. It was silly of me to assume I could provide you with something of completely no value whatsoever, waste your time and then attach such a large amount to it.
Regards, Finn.
Date: Tuesday 14 Oct 2008 11.18am
To: Finnster
Subject: Re: Re: Re: Re: Re: Whose spider is that?
Attached <spider2.gif>
