Which truck is the ultimate basher ?
speedy
Which truck is the ultimate basher ? - 10.25.2009, 02:27 PM
Hi !
I'd like to by a monstertruck och truggy to put an extreme bl-setup in :O) like 6-12s lipo and big neu motors !! So now i need a duarable truck plattform to start with !! but witch one ? flux ? savage xl or what ?
wallot
wallot's Avatar
10.25.2009, 03:30 PM
LST . savage has weak diffs
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
88gtanotchback
10.25.2009, 03:51 PM
weak diffs that are easily upgradeable. the rest of the savage is very tough!
diffs options are cens, which require modifying, or the "bullet proof" ones HPI recently released which are very tough. i have both and they hold up perfect, when properly shimmed.
bdebde
That's All Folks!
bdebde's Avatar
10.25.2009, 04:15 PM
Muggy = monster truggy
skellyo
skellyo's Avatar
10.25.2009, 04:27 PM
Not with the new diffs available for it.
Slowkrawl
High-Voltage Fetish
Slowkrawl's Avatar
10.25.2009, 04:43 PM
I run a flux on 6s, and went to nitro savage diffs shimmed a hair tighter. I pulled them out a couple days ago and they are still PERFECT. I completely blew up stock flux diffs, but the nitro gears worked fine. HPI is sending me the bulletproof diffs so I will run those next summer.
Just clarifying that savages do not have weak diffs, I would be more worried about a revo.
10.25.2009, 05:43 PM
Lst diffs are better than the savage. I like the lst layout better than the savage. The flux is pretty good stock, but the lst is better when converted.
I also have a muggy, and I almost like it better than the lst. If I had to choose I would go with the muggy. Hadles a little better for my bashing style.
10.26.2009, 12:24 PM
+1 on the Muggy- it has all the epicness of a big truck, yet the superior handling and layout of a truggy from what I've read and seen.
bigboi146
Multi Tasking
bigboi146's Avatar
10.26.2009, 01:42 PM
Hyper ST!!!!
Finnster
KillaHurtz
Finnster's Avatar
10.26.2009, 01:57 PM
I like my SavageXL alot. Big, tough and drives over everything. Not the best for high speed handling tho. Turning radius is terrible, and I've replaced the phillips head screws w/ hex heads where ever possible. Stock diffs blew, but the CEN diffs have held up for a long time. Have not used the new bullet-proof diffs, but the machined ring gear and pinion will be even stronger then the cast CEN R&P. The spiders on the Cens are still stronger tho. Overall is a really easy truck to work on and good platform for mods. Parts are dirt cheap on ebay.
I had a muggy briefly I was going to convert. I drove it for 1 gal or so as nitro, but some things really pissed me off about it, so I sold it. I hate how Losi mixes metric and SAE screws. You are always guessing which is which. Some screws are just odd. Who has ever seen a 5-40 screw before? Try finding one in the LHS. I needed 7 different wrenchs to get to all the screws. I didn't like the servo saver either.
Other than that tho it was a nice truck, clean layout and handled really well. Probably better suited for as a big truck that you want lots of speed out of, but if you don't want a full blown truggy. Won't have the ground clearance and climbing ability of a savage, but will destroy it in more open or high speed drving.
Semi Pro
Semi Pro's Avatar
10.26.2009, 02:26 PM
i have owned both a brushless savage and a brushless lst2
it lst2 is by far a better basher and if you ever wanted it be be faster and handle better all you have to do is muggify it
10.26.2009, 08:56 PM
Originally Posted by bigboi146 View Post
Hyper ST!!!!
riverat1540
riverat1540's Avatar
10.26.2009, 09:22 PM
i say the muggy as well, shredding tires will be your only problem, drivetrain is solid and it can handle taking a tumble even at 13-14lbs with. plenty of upgrades available.
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
10.26.2009, 11:15 PM
I know its Halloween but "Witch" truck?
I'd go for a truggy over a MT for resilience personally...
speedy
10.27.2009, 04:39 AM
Sorry ! i ment "which" How do i edit my post's ? i can't fint any edit button ?
