Mike's Custom Motor Mount to mount Tekin T8 motors in a Savage Flux!
Kenny135
Mike's Custom Motor Mount to mount Tekin T8 motors in a Savage Flux! - 11.12.2009, 03:15 PM
This is a custom motor mount that Mike, made me so I could install Tekin's T8 motors/esc in my Savage Flux. I'm not sure if hes going to list it as a normal item for sale on his website so if your interested contact him for one. The silver one in the pictures is the custom mount and the rear one is the stock mount. Thanks for all the help and the great mount Mike!
ID:	7961   Click image for larger version
ID:	7962   Click image for larger version
Kenny135
11.12.2009, 03:16 PM
more pics
ID:	7964   Click image for larger version
coolhandcountry
coolhandcountry's Avatar
11.12.2009, 03:45 PM
Where is the truck?
Peace!
Country
Help support the
Rc-Monster
Buy here
11.12.2009, 04:41 PM
Originally Posted by coolhandcountry View Post
Where is the truck?
Was thinking the same thing..let's see it mounted!
Kenny135
11.13.2009, 01:30 AM
I am going to be doing a complete tare down on the truck and going to rebuild it with lots of aftermarket parts. I have graphite extended chassis plates, graphite motor mount, graphite servo mount, graphite bulkhead lower plates and graphite shock towers from Platinum RC Products. I also have Golden Horizon Aluminum Bulkheads, HPI Machined Bulletproof Diff Bevel Gear Sets, HPI High Speed Idler Gear and Shaft Set, HPI HD Drive Gear, HPI Light Weight Drive Gear, HPI Light Weight Idler Gear, HPI HEAVY DUTY SERVO SAVER SPRING, and finally a Hitec HS-7955TG servo. So as you guys can see I'm going to be busy
ID:	7971   Click image for larger version
11.13.2009, 05:07 PM
Looks great! Look forward to seeing your finished truck! Keep the updates coming
coolhandcountry
11.13.2009, 04:44 PM
Keep them coming.
Looks simple enough.
Looks good.
Peace!
Country
Help support the
Rc-Monster
Buy here
scarletboa
scarletboa's Avatar
11.15.2009, 03:10 AM
just curious, why did you switch out the stock motor for the tekin?
88gtanotchback
11.15.2009, 01:53 PM
if your going that far you should go for a suspension conversion kit from HPI as well as the aluminum big bores.
sounds like my dream flux tho, keep us posted!
