Mamba 25
DLS II
Mamba 25 - 12.14.2009, 03:50 PM
Hi, I just finished downloading 3.22. Updated my 1/10 Sidewinder,MM &MMM. When I plugged in my Mamba 25 it didn't "see" it. Does it need to be sent in? Thanks,Don
brushlessboy16
brushlessboy16's Avatar
12.14.2009, 04:07 PM
Do the lights come on?
12.14.2009, 04:12 PM
Also, did you perhaps remove the red wire to use an external BEC? If so, the red wire needs to be there...
DLS II
12.14.2009, 05:05 PM
No lights and the red wire was not removed. It does work-it is currently configured to run brushed motors. Don
12.14.2009, 05:16 PM
Stupid question, but are you plugging in the link correctly into the throttle cable? If it's the linc style that has the three bare pins, try flipping the throttle connector. If it's the wrong way, the ground and signal wires will be swapped.
DLS II
12.14.2009, 08:01 PM
I plugged it in the same way I plugged in the Sidewinder and the MMM-they worked-I'm puzzled! Don
