Wing mount on flm towers
bigabike
Wing mount on flm towers - 02.25.2006, 12:37 AM
Hey guys,
Does anyone know of a wing mount that will directly bolt on the FLM towers? Tower are on the way and I was hoping shock mounting holes might do the trick.
Thanks!
squeeforever
squeeforever's Avatar
02.25.2006, 01:42 AM
i it will. dace makes some towers for a wing if you cant make something.
your signature, you've fried all of those?
bigabike
02.25.2006, 01:55 AM
Thanks and yes cooked all of them!
Can't figure it out. Been working with Mike and others here, but I still have no idea what the problem is.:mad:1
maxxdude1234
maxxdude1234's Avatar
02.25.2006, 09:05 AM
thats gotta be expensive....
PS. I've got the old style gorillamaxx towers, and although I havn't tried it, 4 of the shock mounting holes line up almost in the exact same way as the Dace holes for the wing mount. As for the FLM towers, I doubt you'll be able to get a tower attached to it...
bigabike
02.25.2006, 04:29 PM
It was/is Mike is going to take a look at my setup for me, hopefully we can figure it out.
coolhandcountry
coolhandcountry's Avatar
02.25.2006, 04:19 PM
I was thinking of mounting a wing as well. I think mike is supposed to get some dace towers in. So you can get them and mount a muegen wing mount right to it.
Peace!
Country
Help support the
Rc-Monster
Buy here
bigabike
02.25.2006, 04:26 PM
That's cool. My FLM's are already on the way so I will probably mod something up.
squeeforever
02.25.2006, 04:50 PM
have you thought of trying the stock chassis to see if that gets rid of the problem? something might be grounding out on it or something.
bigabike
02.25.2006, 08:36 PM
Interesting idea. I put two layers of shrink under anything that was in contact with the chassis, but I just may have to try it. Only problem is I think both controllers are gone. I know one leg on a cap of the 12020 is gone.
Thanks!
coolhandcountry
02.25.2006, 05:16 PM
Have you check to see if your motor screws are to long. It would short out and cause it to draw to many amps.
Peace!
Country
Help support the
Rc-Monster
Buy here
bigabike
02.25.2006, 08:37 PM
I used the stock mounting screws. Are they too long?
squeeforever
02.25.2006, 05:35 PM
true. i was actually thinking about something like that. i have heard that if a motor goes bad sometimes it will fry the controller and the batteries.
MetalMan
MetalMan's Avatar
02.25.2006, 08:45 PM
Did you feel resistance as the screw was almost fully in (before it was actually all the way on)? If you have a Dremel, you could shorten them a millimeter or two.
bigabike
02.25.2006, 09:15 PM
Good question, I just did a test and they are not too long.
Thanks for asking.
coolhandcountry
02.25.2006, 09:18 PM
If you have a stock mount and a clamp probably not. It may be close though. If you look thru the hole of the motor where the screw goes does it look like it has contacted the winding.
Peace!
Country
Help support the
Rc-Monster
Buy here
