i have a set of 2s5100 polyrc lipos and both of them take about three hours to charge . is that normal ? if so, i need to get a new charger and power supply with higher charging capabilities .
What charger and balancer are you using? Even a 50w charger should be doing those packs in 1 hr each. My Hyperion 0606i ac/dc is a 50w charger with a built in power supply and will charge a 2s pack at 6amps so even a 6000mah pack would be done in an hr at A 1C charge rate. For those packs to take 3 hours your charging at less than 2amps or the balancer is doing something wrong. One thing I have learned is that a good charger is well worth the money, I have the Hyperion I already mentioned and a duo, both are great chargers with built in balancers and do just about everything. They may not be the cheapest chargers but I have never heard of anyone having any issues with them or with their lipos burning up while charging with a Hyperion. We spend tons on the lipos and the vehicles they go in so a decent charger is a must!
the hyperion eos 5idp is able to charge to a max of 5 Amps - so it should take nearly 1 hour. You should charge them with a minimum of 1 Amp. otherwise the hyperion eos 5idp will probably stop after 66 minutes and the lipos are only charged 1/3.
I had a 5i for about 3 years and while it is a good charger, it takes a while to charge being a low wattage charger. It should be charging those 2s packs in about 90 minutes though, it still has enough wattage to maintain 5 amps all the way through the CC part of the charge. Are you saying it takes 3 hours to charge both of them or 3 hours each? 3 hours for both is typical for a 1C charge rate due to the CV phase of the charge, 3 hours for 1 battery means something is wrong. I replaced mine with a 1210I and have been charging "1C" charge rate lipos like my Rhino 2150 packs at 1.5 and 2 C without a problem and they get done in under an hour (and you can set it to only charge to 80%, which cuts a LOT of time off the charge if you're in a hurry).
it takes just over 180 minutes to charge each lipo , it also does the same thing with my true rc 2s5000 lipos . yea i think its time to get a 720 i net and power supply . thats just to long to wait for these things to charge up .
That does sound odd. Since it is starting at the proper 5A, I wonder if the built-in power supply is not functioning right. Does this charger also have a 12vDC input? Maybe you could try it hooked to a car battery and see if it still takes the same time.
I don't have the same charger but I have accidently set my charger to Lion and it would act as you describe and take about the same time. It would start charging and would hit the Cv then drop slowly usually until it timed out depending on SOC.
Jeff
Could also be cells that are enough out of balance to cause the charger to drop back the current to give them time to equalize. That is assuming you are using the data cable between the charger and LBA...
