Go Back   RC-Monster Forums > Support Forums > General Nitro
k&N air filter HAHA!
t-maxxracer32
t-maxxracer32's Avatar
k&N air filter HAHA! - 01.27.2007, 10:37 PM
http://cgi.ebay.com/K-N-Air-Filter-T...QQcmdZViewItem
anyone seen that before?
lol
how does it perform? might get one
my real truck has one too and it actually is a nice little upgrade!
o and btw i have the os 18 motor if it matters.
01.27.2007, 11:13 PM
LOL, nice little filter. When I was using Nitro, I used this with good luck.
I don't know about those little K&N's, but the real 1:1 versions need special cleaning solution and/or oil. The motorsaver uses regular dishsoap to clean and regular filter oil...
t-maxxracer32
01.28.2007, 12:09 AM
i probbaly woudlnt buy it i just thought it was cool! lol
squeeforever
squeeforever's Avatar
01.28.2007, 12:40 AM
No!! Don't go with either...Like Brian said, the K&N's require special maintance, and aren't that great in performance. I would go with the stock snorkle for the Revo and a 1/8th scale buggy filter modified to fit it. That way you don't have the stock restriction of the mesh. A prefilter might also be smart. The Motor Savers are a no-no as well because I have heard numberous horror stories of them coming open, letting the element come out and then sucking dirt into the engine. If the filter comes off, you might as well kiss the piston and sleeve goodbye. I had that happen once with the stock filter because they don't come with a zip tie around them from the factory...
01.28.2007, 01:37 AM
Really?? I never had any problem with the MS on my Revo. Does the filter assembly come off the gooseneck? If so, I glued a stock Revo intake header on there so it never came off.
I do agree though; ANY amount of dirt in the engine will SEVERELY shorten its life. The way the piston and sleeve are designed in those engines leaves no room for error on that part!
GorillaMaxx360
GorillaMaxx360's Avatar
01.28.2007, 01:19 AM
that actually apperas to be a real car airfilter that some one decided to say was for the nitro rc cars. There is one air filter on a car the main one that is like 1 ft long but there is also one about this size conected to something else (what it was conected to sliped m minde but i have seen these small air filters on cars before they have a certain purpose i just cant remember). But yeah i would stick with the ones for the smaller blocks.
crazyjr
crazyjr's Avatar
01.28.2007, 01:43 AM
The guy that created the Cvec exhaust is advertising a fram air cleaner. I didn't think too much about it because of the people using oil breathers on Ebay, but they used fram's name in advertising, so they may be collaborating on it. If i find the ad i'll get the link and post it
biddy
08.29.2007, 08:02 PM
by the way, the best way to clean air filters is to use mineral turpentine (a type of paint thinner that can be purchased at harware stores). HPI recommends using nitro fuel, but that is expensive compared to mineral turpentine.
And NO YOU WON'T DAMAGE THE FOAM. I , along with every one else in the dirt bike world have been using mineral turpentine with 100% success.
turpentine is a solvent of air filter oil, so if some turpentine remains in the filter it will just mix with the oil (you don't want much residue though since it will thin the oil too much).
using water and detergent is a bad idea, since water almost always remains in the foam....not good. plus it is an ineffective cleaner compared to turps.
never use gasoline, since it will make the foam swell and break down over time.
i heard on other forum that people are so paranoid about their "expensive" nitro engines that they put a brand new filter on every time.
My dirt bike engine is worth thousands of dollars alone, but i clean my air cleaners since the foam can last around 30-50 or so washes before falling apart.
squeeforever
08.29.2007, 08:35 PM
I actually had one swell when I washed it with nitro at a race. So personally, I would never use nitro. It swole immidiately and ruined it completely...
squirlz
08.29.2007, 08:16 PM
dont use the K&N type of filter on a RC engine. They do not filter out enough to keep the motor clean. the foam filters trap much more dirt and even better with a pre filter. 1:1's can handle a little more dirt in the motor than the precision rc motors.
biddy
08.29.2007, 08:41 PM
also, if you run your truck in very fine and dusty clay soils, be warned that these super fine particles will pass straight through any air filter. in australia, some of the particles are down to 2 microns in size (in places) and most dirt bike filters only trap particles above 5 microns. RC filters are no different, it depends on the type of foam used.
though, the finer the foam the more intake restriction you will get.
paper elements are ok if they are used with a oiled foam pre-filter. however i would recommend sticking with just oiled foam.
biddy
08.29.2007, 08:42 PM
hey squeeforever, i have never used nitro fuel to wash the filters since the methanol temporarily makes the foam swell right up. HPI recommends it, not me...i recommend mineral turpentine.
my 2 cents
my 2 cents - 08.30.2007, 10:20 PM
i use k&n filters all the time. If you check out their website, they have a r/c specific filter, but they are all connstructed the same, most on e-bay are actually oil breathers. In fine dust use a pre-filter, other than that keep it clean and well oiled, i've had lots of luck with them and actually had my engine temps come down because of the easier breathing
ID:	3162   Click image for larger version
08.30.2007, 11:10 PM
wow, a thread about air filters for a nitro truck.
I think I will get one and mount it b/t my fan and the mm so that dust does not build up on the cooling fins and ruin the transfer efficentcy!
biddy
08.31.2007, 12:16 AM
well this is the nitro section.......
