Timing advance
Stoomstrijkijze
Timing advance - 08.16.2010, 09:54 AM
Hi Castle,
I'm sure you guys read about the new feature on the Tekin speed control. I read on serveral boards that it helps the temps down and the top is higher. The team drivers went from 2050kv to 1900kv on 4S and from 1900kv to 1700kv.
What it does:
When you hit a certain RPM, lets say 22k rpm, the timing goes up with a predefined value and you are able to reach high speeds on the straights. When you going back under the 22k in the corners/technical parts, the timing goes back to 0° for more control and efficienty.
I guess this would a nice feature for the MMM ESC's too. You'll be able to use lower KV motors, more efficiency, lower temps, easier to drive, same/higher top speeds and that with the reliability of an MMM ;-)
I think a lot of racers are interessted in this feature. Please let us know what you think about it!
