Lowest "Safe" voltage for 2s? -
09.22.2010, 05:56 PM
Just wondering, what's the lowest "safe" voltage I should see on my 2s packs after a full run? (The voltage the charger sees when first plugged in) Thanks
R.I.P. Muggy, Rustler, VXL Slash
EFlite Blade MSR Heli (Slightly modded)
1/16 BL E-revo
8-t 2.0, OS Vspec with Speed conrod
Carbon Fiber Revo 3.3 Coversion Madness!
09.22.2010, 06:02 PM
Most chargers will not even charge if the voltage is under 3.0v per cell, its in the programming
09.22.2010, 06:20 PM
Ok, but what's a safe voltage for the batteries?
1/16 BL E-revo
Soldermaster Extraordinaire
09.22.2010, 06:52 PM
Oh no! We're stuck in an endless loop!
09.22.2010, 07:30 PM
So as long as it doesn't read 6.0V I'm fine?
1/16 BL E-revo
09.22.2010, 08:00 PM
Most here run 3.1V voltage on their cut-off and the batteries come back to 3.3 to 3.4v per cell as they cool down. I personally run my cut-off to 3.0 and charge when cool and have never had troubles with any good pack. My maxamps puffed within a year but my hyperions and flightpowers have lived over three years and still going strong
09.22.2010, 08:15 PM
Even if the cells are below 3V at rest, all is not necessarily lost. You can try charging them very slowly (like 1/10C, 0.5A for a 5K pack) and see if they retain any capacity. Bear in mind you should be watching the charge cycle closely in case the pack decides to puff.
Fat Kid Engineering
09.22.2010, 08:29 PM
High qaulity packs, Hyperion, ThunderPower etc (excludeing MA) will come back just fine if cut off is at 3.0 per cell but still should be set at 3.1-3.2
The cheaper packs IE HobbyCity, Blue Lipos, Batman etc I would use a consevative cut off of 3.4-3.5 to be safe. These packs seem to really struggle getting back to where they need to be when drawn down to low.
09.22.2010, 09:08 PM
i cut at 3.2v thats what hyperion recomends
Originally Posted by Semi Pro
Originally Posted by BrianG
09.22.2010, 09:23 PM
Ok, pack was at 6.5v, so it should be fine? For some reason I had though below 7.0V was bad, no idea why...
1/16 BL E-revo
09.26.2010, 02:34 AM
yes, it's fine. I also have no idea why you thought that.
09.26.2010, 04:41 PM
I think I need more sleep...
1/16 BL E-revo
Fat Kid Engineering
09.26.2010, 04:54 PM
Yeah, you look like shiz ?
09.26.2010, 09:16 PM
Do you have a camera in my home? Haha
1/16 BL E-revo
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
