serpent 811 cobra conversion
zixxer
zixxer's Avatar
serpent 811 cobra conversion - 11.07.2010, 09:41 AM
Hello rc monster
I was wondering if there is plans or an eta for a serpent 811 cobra conversion kit .....sorry if this is in the wrong area ....and thanks in advance for the response
LATER ZIXXER
BIG FISH EAT LITTLE FISH
SERPENT 811 COBRA/E TEKIN RX8/1900
TEAM VP PRO USA ~ TEAM DIALEDINC
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
11.08.2010, 03:27 PM
I have built the car and am about to get working on the conversion - should be ready in the next couple weeks.
zixxer
zixxer's Avatar
11.08.2010, 03:49 PM
Hells yeh. Can't hardly wait. My kit should be here in a week. Can't wait to get some rc monster goodness strapped up and get going.
Thanks a ton
LATER ZIXXER
jzemaxx
11.09.2010, 05:27 PM
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
11.09.2010, 08:44 PM
Guys..I know that this is a new kit and all, but what is the hype all about. Most of the major mans buggies today are so well built as it is...just don't understand why some people have to have the newest thing on the block
nitrostarter
nitrostarter's Avatar
11.09.2010, 09:03 PM
guys..i know that this is a new kit and all, but what is the hype all about. Most of the major mans buggies today are so well built as it is...just don't understand why some people have to have the newest thing on the block
+1...
N. Rustler conversion
el tomaso
11.11.2010, 12:42 PM
Where do I find this kit, pics would be nice.
Thomas G
jzemaxx
11.15.2010, 10:48 AM
Once you drive a serpent you will know.
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
11.15.2010, 10:25 PM
ok, enlighten me about them. I have 3 different mugen rides...MRX-3 1/8 on road, mbx5 and mbx5T. All of the mugen line is really sweet. I know serpent rides are not cheap...so what's really the difference?
brushlessboy16
brushlessboy16's Avatar
11.16.2010, 12:16 AM
Think of diesel and gasoline.. both burn but one is more refined.
1965 mustang vs a 2011 stang. both have four wheels,a motor.. but the newer one would handle loads better.
improving designs doesnt always mean drastic changes.
little things can make a difference.
11.16.2010, 09:35 PM
I understand
jzemaxx
11.22.2010, 06:09 PM
I'm ready to order..... ;)
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
zixxer
zixxer's Avatar
11.27.2010, 10:16 AM
me too ...hey mike any word on the conversion ...got my kit the other day ...im ready to rock this conversion
it would be easier for people to just look at the design of the serpent and then make a decision based an the technical advancements of the car ....btw i dont want the flavor of the day just the best buggy out right now ...i ran a losi all this year and im just ready for something different .. it was either
serpent
jq
or team durango
sick of the same ole losi an mugen dance
LATER ZIXXER
zixxer
zixxer's Avatar
11.27.2010, 10:24 AM
Features:
Geometry: With over 15 different manufacturers tested and countless hours of driving, the geometry is well proven. So many different concepts and suspension styles have been taken into account; any driver will be more than pleased with the S811 Cobra package. The geometry is set up for maximum performance with the most efficient cornering in mind. Utilizing proven roll centers, shock progression and camber links.
Weight Balance: The front to back and left to right balance have been greatly enhanced over even some of the most recent buggies. You will definitely not find one side of this vehicle dragging the ground over another. The balance is perfect and it is barely if at all affected by the different types of batteries available.
Gear Ratio: The S811 Cobra’s 4.3:1 gear ratio has been proven to give you the most possible acceleration and also allow you to use a much larger variety of clutch bells. This gives the racer the option to gear his car down on a short track if needed. Attention to small details such as this can be the difference between winning and losing.
Suspension/Shocks: The suspension is comprised of suspension arms that are almost identical in length, to allow you to maintain corner speed, as well as aid in rough track handling by using proven design concepts and updating them for modern day competition. The 16mm Big Bore shocks will allow you to soak up even the harshest landings on any track world wide as well as help to prevent thermal break down of the shock oil during long mains.
Engine Placement: The engine location is a forward placement design and has been maximized to allow for forward placement. But an ideal placement has been found to allow for aggressive handling without compromising the cars overall balance.
4 Shoe Clutch: After countless hours of testing different types of clutches it was determined that a 4 shoe clutch was the best overall choice. Allowing the racer the ability to balance the clutch for carbon and aluminum shoes, as well as utilizing the simplest building concept, the S811 Cobra clutch allows the user to mix and match clutch shoes to perfectly tune the clutch to the specific track conditions. The S811 clutch system will also allow the user to build multiple units that can be changed out quickly.
Steering System: The S811 Cobra steering system is the most advanced system ever devised. The bell crank system is angled to better match the caster angle, with an optimized turnbuckle length to eliminate bump steer. The brilliant ackerman design allows changes to be made without the need for link adjustments. Simply change the ackerman plate, reset the radio endpoints and hit the track.
Body & Rear Wing: The S811 Cobra body is extremely low profile and fits the chassis like a glove in all the right places with equal proportion cab and sides. The rear of the body is scooped to provide additional down force, which helps guide air to the rear wing. The wing has a combination of different air foils with 2 fins inside of the side damns to aid in keeping the rear of the car planted while providing great side grip and excellent control while flying through the air.
Anti-Roll Bars: The kit anti-roll bars are a conventional type, produced with bent piano wire with laser engraved identification marking. But the S811 Cobra Roll Bars are supported by ball bearings to insure they never get sloppy and provide consistent control. An additional anti roll bar kit will be available as an option that is very advanced and even easier for the racer to adjust the wire sizes on the fly.
Ball Bearings: The differentials, drive shafts, and all other ball raced components are supported by high quality rubber sealed bearings and are as good or better than the bearings included in any kit.
Fuel Tank: The fuel tank utilizes a floating clunk design so the engine wont starve if the car spends too much time on its lid, while the tank top has an overflow to help guide any unwanted fuel out the bottom of the chassis. The tank lid has been designed to minimize splashing during pit stops, as well as prevent fuel contamination to the critical parts inside the vehicle.
Transmission: The transmission drive shafts are all captured, so never again will you worry about losing a pin in long main or at local events. It has been designed so that no matter what, your drive train will stay assembled so you will finish any event without troubles regardless of the race length. The drive shafts are produced using tool grade spring-steel and coated with the unique Serpent factory brown finish. They are also laser etched for easy identification. You will not be disappointed in the quality and strength here.
Brake System: The brake system has been simplified to help you set your brake system the same every time, no matter how many cars you build. The parts have also been lowered to help keep the CG as low as possible. It uses a piston system and provides superior braking like you have never felt before. Several optional brake upgrades will be available to fine tune the braking system in a way that has never been seen before.
Servo Linkage & Camber Links: The servo linkage and camber links have been captured to eliminate the worry of losing a ball cup when you are on a TQ run. This car was developed with one thing in mind, to finish first, you must first finish.
Electronics Installation: The electronics installation may be a little tricky the first time, with a couple new steps you have never had to do before. So for some it will be a bit foreign, however after you do it a time or two you will appreciate the packaged unit you get when finished. The assembly is very clean, tidy and simple to remove from the car with no parts that look like they are just barely hanging on and out of place.
Chassis, Chassis Stiffeners & Flex Control: After lots of testing the plastic stiffeners that are provided in the kit control the flex in all the right places to help you make it through the roughest terrain. The car is not too rigid, but also is not too flexible.
LATER ZIXXER
jzemaxx
11.29.2010, 10:06 PM
Any updates.....two more kits built and no conversions
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
