Can the stock Savage Flux motor mount accept 36mm motors?
micke_b
Can the stock Savage Flux motor mount accept 36mm motors? - 02.12.2011, 05:11 PM
Can the stock Savage Flux motor mount accept 36mm motors? I have a NEU 1415 laying around, 36mm diameter. Will it fit?
02.12.2011, 06:30 PM
No. The flux mount is for 39mm motors. Unless you can make a spacer to put around the 36mm motor.
josh9mille
josh9mille's Avatar
02.12.2011, 06:47 PM
Or you try to find one of those "motor expanders", that should be able to stretch it out the 3mm you need.
02.12.2011, 07:32 PM
Like a tailpipe expander that exhaust shops use? Should work like a charm!
micke_b
02.13.2011, 05:12 AM
D'oh!
josh9mille
josh9mille's Avatar
02.13.2011, 11:19 AM
exactly!
Knez
Knez's Avatar
02.15.2011, 04:40 PM
This is where i got my last motor clamp for 1520 and u can also get 36mm motor clamp for flux! ;)
http://www.alza-racing.com/product.php?id_product=3
Flux 5B CC 1520
1/16 Rally
My Youtube
Russian:Life and Trust is Lost Only Once!
micke_b
02.16.2011, 02:14 PM
jepp, thanks, got that place in a pm as well. :-)
FR Rayward
02.17.2011, 04:38 AM
Yes, you can. I run a Medusa 36mm wide motor in my Flux. I used a couple of angle brackets, and cut them to size. Make sure they are a very tight fit. You may have to shave the pole spacers (that the screws go through) to get some more clamp on the motor, but not too much as it may snap.
