Building A Drag / Street Ve8 Buggy Need Advice !
The Overclocker
The Overclocker's Avatar
Building A Drag / Street Ve8 Buggy Need Advice ! - 02.15.2011, 12:01 AM
ok so as the title says it all
here is what i came up with
the only thing i own so for is the * HotBodie Ve8 kit buggy & Dx3R remote control *
this is what i think i need , correct me if im wrong ! * im a nooooooobie ... but that did some home work a little ! *
HHH chassis
Savox SC-1268mg
Ofna belted street tires
Kyosho IFH002GM
60mm 98GF Spring HB
Lipo --> http://www.hobbypartz.com/98p-40c-50...-hardcase.html
icharger
Pc Psu 1000w
23-26 pinion
wires
tire glue
6.5mm quick connectors
heat shrinks
tie wraps
optional parts that would look cool
Jconcept ve8 illuzion body
flat black paint
nice aluminium wheel cap bolts
cool lights ---> http://www.rc-lights.com/products/RCL5014.html
new wing --->http://prolineracing.com/wings/high-...ce-black-wing/
cool cam --->http://www.hobbypartz.com/wosm2mispy...ProductReviews
Aluminium wheels --->http://www.nitrorcx.com/51c00-816121.html
so building a drag buggy is a little tricky ...
but i will never see a r/c closed track aka ROAR rules will never be expected
i want to be able to go from 0-100mph very fast , wile having traction + a impressive play time ... like 30min-45min full trottle
this buggy will ONLY see hot asphalt , at the drag strip or a nice street
engines setups i came up with so far
#1 choice
Mamba XL
1515 2.5d 1700kv
8s
4.2v cell - 55,440Rpm /3.7v cell Normal 48,840Rpm
#2 choice
mmm pack 2650kv
6s
4.2v cell - 66,780Rpm /3.7v cell Normal 58,830Rpm
approved by castle its self
#3 choice
Tekin Rx8 & T8
2050kv
6s
4.2v cell - 51,660Rpm /3.7v cell Normal 45,510Rpm
hoping this project could work i need some input on what setup to chose and any additional stuff
special thanks to Jeff for the help along everything * aka drknow65*
and sorry for my english
PBO
RC-Unobtainium
PBO's Avatar
02.15.2011, 05:17 AM
100mph in a buggy isn't too hard
I wouldn't buy those alloy wheels, you'll bend them & end up throwing them away. Buy pre-mounted belted tyres (not sure if the Ofna's are still available) like GRP M01's
http://www.grpgandini.it/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=66&category_id=25&option=com_virtuemart&Itemid=6〈=en
Use your choice second motor/esc combo for pure speed runs only (will get way too hot after a few passes) otherwise get the 2200 combo & run 6S but be prepared to gear down a little to manage heat while you're not trying to set records
Lower all the shocks (6-8mm) by installing fuel tube internally on the shafts
For speed runs; gear it to the moon, don't run at night & make sure there are no kids or animals around
Get video
Enhanced Rustler 1515 1.5 MMM
Losi 8ight-T
reno911
Smelly Nitro meet your maker!
reno911's Avatar
02.15.2011, 02:56 PM
I love speed builds, just never had the courage to build one myself, something about dirt and jumps just makes this hobby so much fun.
Pretty extensive list of goodies.
It is a hard choice on the Motor... I would say a 1800 on 6s and gear it crazy.
Why not stick with the stock chassis for weight savings?
The Overclocker
02.15.2011, 09:33 PM
love the aluminium look
TexasSP
Something, anything, nothing
TexasSP's Avatar
02.15.2011, 11:43 PM
Going high speed is not about looks and add ons, it's a bout speed and if what you are doing doesn't help the vehicle for the purpose, don't use it.
All the lights and BS take up space, add weight, and don't do anything to make the vehicle faster. Just breaking 70 mph in an rc is an experience. When you get up to 100 the effects compound. It's trickier than it appears.
Just from an aerodynamics standpoint and keeping the vehicle on the ground you are in for some work and a lot of trial and error.
Good luck though!
www.cubicle101.com
Overdriven
Destroyer of Tires
Overdriven's Avatar
02.16.2011, 12:27 AM
I think the biggest suprise is going to be the fact that play time is going to be limited while waiting for everything to cool down when geared so high. 30min runtime is no problem when you count the 5 min of cool down time after 2 minutes of running. Get a big motor if you're going to keep it geared high all the time. 1717 or a 1527 have alot more torque to pull that kind of gearing and won't heat up as fast.
The Overclocker
02.16.2011, 01:12 AM
wont fit
thats why i chosed the 1515
the ve8 has maximum 76mm clearence , or else it rub's on the steering post
PBO
RC-Unobtainium
PBO's Avatar
02.16.2011, 02:13 AM
Have a search through some older threads, there's more than enough go fast info about buggies...like this one
http://www.rc-monster.com/forum/show...hlight=100+mph
Losi 8ight-T
The Overclocker
02.16.2011, 02:53 AM
yeah he's a guy from my hood , listen im worried he's gething 100mph speeds with 34tooth spur & 25 tooth pinion
im stuck with my 50tooth spur gear and a 4.3.1 diff ratio
whats my solution ?
simplechamp
simplechamp's Avatar
02.16.2011, 03:27 AM
What's the issue preventing you from using a smaller spur? And also 3.3:1 standard buggy diff ratio?
The Overclocker
02.16.2011, 04:23 AM
I can use a rc8 center diff + 43t spur but for the diff ... Forget it to much work
If i gear this to high i wont have the torque i need for drag starts
Id rather stay stock spur
TexasSP
TexasSP's Avatar
02.16.2011, 09:54 AM
FYI, it's going to take work for 100 mph to happen. Your going to have to do some customization somewhere. This isn't a cookie cutter deal.
If you're expecting to just slap everything on and being busting 100 this week, you are in for a surprise.
www.cubicle101.com
simplechamp
02.16.2011, 07:51 AM
You can use Jammin and Kyosho spurs with your HotBodies center diff, so you could use a 48T, 46T, or 44T. That's enough to squeeze out a bit of extra speed, and if you keep the 4.3:1 F/R diffs there still should be plenty of torque with a quality 4-pole motor on 6S.
Most options for increasing speed will reduce overall torque (higher rollout from either bigger tires or lower gear reduction, higher kv motor). The other main option is increase the voltage, but along with that come a few other things to consider.
I have a 44T Jammin spur that is too small for my gearing, like new, if you want to give it a try let me know.
The Overclocker
02.16.2011, 02:41 PM
thanks dude
as for the drag and speed runs ... they have to be combined !
i need this buggy to do 0-100mph very quick !
the average fast drag car real scale is going to rip me if i cant have fast start ups and be able to hit 100mph atleast , they cross the line at a average 100mph
so i need the drag & speed setup in one buggy
is it possible ?
heat ... listen 1/4 mile isint much run time , i could expect it to get hot but not worried it wont burn because a 1/4 run if im lucky i could get 10-14 second run time , then if i just want to play with it in the streets or what ever , i could set my remote control to give 80% of power when i want to play safe nothing should heat up or burn
what do u guys think ?
thanks !
snellemin
2 KiloWatt RACER
snellemin's Avatar
02.16.2011, 11:03 AM
Dragracing and speedruns require different gearing. You can't run the same gearing for both, as one setup is for acceleration and the other for speed. Soft belted tires for Dragracing and Hard belted tires for speedruns.
My preferred motor choice are 2 pole for dragracing and 4 pole for speedruns.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
