Originally Posted by BrianG
Those weird stall outs may be caused by a thermalling BEC. Can't forget the BEC in this system is linear and running on 3s on even a so-so servo can generate quite a bit of heat. You could try a receiver pack temporarily to see if it cures the problem.
Good idea, I will give that a try.
A long time ago I made an inline deans setup with small wires soldered on that are terminated with a micro deans. I also have a bec with a micro deans wired to it. I just found it while digging thru my adapter wiring drawer. This way I can put the deans adapter between the battery and esc and run a test bec if needed.
Only issue is my test bec is the ccbec that is acting up...
I do have a CCC (cheap chinese crap) bec somewhere that I can try. I am running 2.4ghz so it should not have a noise issue that the CCCs had with my fm radio setups. That was always fun, trying to find a chassis location that did not bother the rx...
