Removal of 2 pole rotor magnet? -
03.25.2011, 12:12 AM
Any ideas how to get a 2 pole magnet off the shaft? I am guessing it is glued on, try some heat? I know I do not want to get the magnet too hot, but...
I have a shop press, and not ing to loose, I guess I could press the magnet off... Might shatter though.
Also, where can I get 5mm motor shafts cheap? I know outrunners use them, try ebay?
FYI, the problem is my c50 maxx motor broke the 1/8 portion of the shaft off, and I figured I would remove the magnet and replace the shaft with a 5mm one.
If anyone has a L can feiago or hacker motor or rotor they do not want, it would save me the hassle...
Can't catch this...
03.25.2011, 01:19 AM
if you have any success, LMK...
03.25.2011, 11:24 AM
The only ones I have delt with are ones that the shaft has come loose and had to put them back on, but I think you could probably get the shaft hot and see if you can press it off. If it were me I would use a torch on the end of the shaft. I am sure you would have to be careful not to get it so hot that the rotor expands and shatters the magnet.
03.25.2011, 11:40 AM
My issue with heating the shaft is that it will expand, and I really want to shrink the shaft, or exand the magnet. Pretty sure you are not supposed to get the magnets over 200f, so I will try to get it up to 180 or so, while it is setup in the press. If I destroy it I do not care, it is useless as is.
03.25.2011, 11:48 AM
I meant shaft. You could try cooling it in the freezer, or some of that cooling spray. I am not sure if that will work, but I am not sure how else to get it loose. Most of the bonding adhesives have a temp well over 200F.
Jeff
Also, be careful how much heat you apply since excessive heat demagnetizes magnets...
2 KiloWatt RACER
03.25.2011, 11:54 AM
Instead of destroying the rotor, can't you make it fit in a B50 Hacker motor or Feigao 540 s size motor?
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
BMW M Power!
03.25.2011, 01:17 PM
He broke the shaft...he's trying to find a way to put the magnet onto a new shaft.
Linc, as I understood the magnets were held on by epoxy. Heat weakens epoxy, as far as I know.
03.25.2011, 02:26 PM
Too short to fit a S can. It broke off where the 1/8" met the 5mm shaft, which is level with the ft bearing.
Can't catch this...
03.25.2011, 02:38 PM
1st gen tekin T8 motors used a 5mm shaft...
I can't be the only one with 3 broken/fixed rotors
EDIT: I just used a vise and the magnet off of said tekin motor to push the hacker one off..
any recommendations on getting it to attach to the tekin shaft?
03.25.2011, 02:25 PM
It came out very easily. I used a 20ton press but you could have used a bench vise, the shaft was barely stuck in there.
Now I need to find a source for a 5mm shaft. Any ideas?
03.25.2011, 02:35 PM
Sounds easy...
03.25.2011, 03:17 PM
Jb weld is what I plan to use. It is high heat epoxy. Will have to set all night, but who cares. I would also sand the area of the shaft where the epoxy will go.
03.25.2011, 03:43 PM
Can't you use some 5mm round bar stock for the rotor?
You could heat it up and quench in old motor oil to harden it.
03.25.2011, 03:46 PM
I was thinking a outrunner motor shaft as those are sold somewhere cheap...
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
