Losi 2.0 vs Losi 1.0
Blaz
Question Losi 2.0 vs Losi 1.0 - 06.08.2009, 02:13 PM
hey guys i am in the process of selling my e-revo roller on ebay and i need to know the differences between the 2.0 and 1.0.because the 1.0 is alot cheaper i think i am going to buy the and maybe start upgrading it slowly with 2.0 parts if the 2.0 is alot better.And 1 more Q shuld i run it with the xcelerion combo 2100kv or the mmm combo 2200kv.Thank you for your time.
nitrostarter
nitrostarter's Avatar
06.08.2009, 02:35 PM
chassis and center driveshafts for sure.
I would stick with the MMM2200 combo. Much better than the Losi system...
N. Rustler conversion
cmcclive
06.08.2009, 02:53 PM
I know a few guys with 8ightEs (running the losi esc/motor) and they love it. I also know a few guys with 8ights they converted w/ mmms and they love it.
From what I can gather the MMM is a lot more customizable and (as long as it doesn't fail right out of the box) a lot more dependable.
Based on user accounts the MMM seems to be more forgiving then the losi system for those not as experienced (at racing).
Shark413
Shark413's Avatar
06.08.2009, 03:46 PM
Chassis and driveshafts longer (driveshaft is actually extra long because 1.0 driveshafts popped out of the drive cups all the time). A-arms are 15mm longer, which means the wheels are now zero offset, different front spindle (has a few more adjustments), different shock towers (lighter), Rear shocks are longer, front turnbuckles are different size, steering bellcrank/servo saver is different, body is different, rear diff case is different (allows shimming). To me the biggest changes were the longer chassis and longer a-arms/zero offset wheels.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
ZippyBasher
8th scale Stunt-Driver/Mechanic
ZippyBasher's Avatar
06.05.2011, 01:13 AM
Ancient Yes. but I need to know if the 2.0 case will work with the 1.0 setup. PLease! Thank You.
Maxx - FLM, MMM, CD Med.36x706s
Raja - FLM Ext. MM, 1512, 4s
SC8ight - MMM, 1520, 6s
D8T - MMM 1717 6s
My OVERPOWERED Rides "CLICK"
Like Playing Cards? Cut-Throat Rummy "CLICK"
Blaz
06.09.2009, 05:10 PM
thanks for the advice.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
06.09.2009, 05:52 PM
Losi's body designer should be fired after designing the body for the 8ight-T 2.0!!! Personally I'm not a fan of Losi but if I had one I wouldn't even bother with the stock body cause I think it's that ugly!!!
stum
06.09.2009, 09:49 PM
They maybe ugly, but they are blowing by ALL other trucks on the track... nothing can touch them.
Blaz
06.13.2009, 09:44 AM
hey how does a rc8 compare with a losi 2.0.I know there probably isn't many differences, it's probably just your preference.thanks.
DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
07.16.2009, 07:34 AM
I've got all of the versions of the losi 8ights. (i just got my 5th one.)
and really all the parts between the 1.0 and 2.0 can be interchanged. even the longer rear drive shaft from the 2.0 fits on the 1.0.
the only reason i even got the 2.0 besides being curious about the handling differences was the same guy i always buy my kits or rollers from sold it brand new super cheap. i got it for $329 as a roller on ebay and threw the mmm combo in it.
i gotta say, the losi brushless system is very disappointing to me. very slow imo. that's why i use all MMM combos in my 8ights. if you can get a 2.0 nitro roller, imo it's better to convert than the 2.0-E.
There are some issues with the 8ight-e rollers out of the box. it seems as some of them come with the plastic spurs and they are too wide for the motor mount and create binding. Some people sand them down to fit, but if you opt for that make sure you do it evenly or the spur will wobble. the solution i used that has worked very well for me is to run the metal 45t spur part # LOSA3552.
the other issue is if you like to do high speed runs like i do, the stock mount will only accomodate about a 16T-17t pinion. my solution...get the RCM motor mount Mike offers. it's awsome. i can run a 25t pinion on that thing, no problem.
if you decide to go with a 1.0 roller, i had issues with blowing dime sized holes in my center diff cup so i got the aluminum diff cups from Nova rc. the new diff cups the 2.0 uses are just as good imo.(just another option.) that solves that problem.
Instead of buying the e-rollers, i got the nitro versions and converting them they way i think they work best. imo, it's cheaper too.
diff cup aluminum:
http://cgi.ebay.com/ws/eBayISAPI.dll...m=390015827060
losi battery tray:(best option...they can accomodate HUGE batteries)
http://www.impaktrc.com/product_info...oducts_id=3195
motor brace:
http://www.impaktrc.com/product_info...oducts_id=3196
receiver servo box:(this is very un-necessary imo because the stock radio tray is identical except it accomodates 2 servos and the rec. pack. all you need to do is dremel 2 1/4" bars off the nitro tray holding the 2 together and it's identical. this will save you some money.
http://www.impaktrc.com/product_info...oducts_id=3194
battery straps:(again, very un-necessary because you can buy hook and loop velcro at any computer store for a third of the price.
http://www.impaktrc.com/product_info...oducts_id=3197
mike's motor mount:
http://www.rc-monster.com/proddetail...d=RCMLosiMount
TBR front and rear bumpers(a MUST imo if you wanna keep your chassis nice)
http://cgi.ebay.com/ws/eBayISAPI.dll...m=350118024775
as far as handling, to be honest, i couldn't tell the difference in handling anywhere between the 1.0, the 1.0 pro roller or kit, the 2.0 rtr or the 2.0 pro roller. they all handle incredibly.
here's a few pics of a few of mine:
the new 2.0 build:
as far as the RC8, it's a great buggy. not as popular as the 8ights where i live, but it a good buggy. what i don't like about the rc8 is it's got a lower gear reduction which gives it more acceleration (which let's face it.. NONE of us need if you track race with the power of almost any brushless system) and less top speed when all other things are equal. this is why i opted for the 8ights.
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
6th
07.22.2009, 04:33 PM
diff cup aluminum:
motor brace:
mike's motor mount:
snip*
the new 2.0 build:
Nice setup, I'm sorry for asking this, but what modifications should be made to the chassis if any to mount the ESC and motor mount
DwightSchrute
07.22.2009, 09:25 PM
no mods are needed for the conversion. the esc mount is on the battery tray of the losi conversion and i just secured my esc with velcro.
the only mod needed for the losi or RCM motor mount is, if you decide to run the plastic spur gear, you will need to sand it (the spur gear) to the same thickness as the steel spur and you won't be able to run over a 45t with any conversion but the tekno conversion.
6th
07.24.2009, 12:41 PM
Brilliant , thank you very much
DwightSchrute
07.24.2009, 10:28 PM
glad to help
