HPI Rs4 electric conversion help..
arvint
HPI Rs4 electric conversion help.. - 06.06.2011, 10:26 PM
Hey..
Friend gave me a pretty beat up rs4...and I made it a project to bring it back to life..in electric form (was nitro)...without spending over $50 (Had the electronics, motor mount got on sale..)..
AND..here's the problem...is there anyway to get that pinion to reach the spur gear?
I searched around and found something like this..but it's the wrong size bore for the motor shaft (Castle's 4 pole 5700 is 1/8" I believe)..
http://www.caswellplating.com/buffs/shaft.htm
With some recent efforts..I got the pinion even closer..
While posting this..I might try flipping the spur gear around..if that works..other wise..I still think i'd be about 1/2 an inch short..
Motor mount will not come anymore forward unless I hack away at it..
So..any thoughts?
Thanks!
EDIT:
Have flipped the spur around..about 1/2 an inch away from the pinion touching the spur..starting to hack away the motor mount...but it'll require alot of dremeling....and time...
