incaseing esc in epoxy ?
speedy
incaseing esc in epoxy ? - 09.05.2011, 12:04 PM
If i incase an esc in epoxy (leaving the coolingfins uncovered by epoxy !! ) will the esc overheat ? i was thinking of making an "icecube" ish block of epoxy around the circuboards to make4 them water proof !
molak
09.05.2011, 01:54 PM
i did that to my MMM any the Bec lost his power. Now i can't power anything with it .
I was at the dunes the fan got stuck with sand... i used the temp gun and the ESC was 70 C°.
I swapped batteries and the BEC stopped working ... The ESC still work!! The bec generates 5v but as soon as you move the steering it drops out..
speedy
09.05.2011, 02:15 PM
Hm but if the fan broke from all the sand then it can't be the epoxy who made it stop working right?
berserk80
09.05.2011, 05:28 PM
Own research in this area
http://photo.qip.ru/users/berserk80/96552427/all/
speedy
09.05.2011, 05:37 PM
Well did it work ?
berserk80
09.05.2011, 06:37 PM
Yes works, I go to these modifications myself
there are certainly pros and cons.
For better heat dissipation in the ESC strive to change thermal interface and features to improve heat dissipation.
09.05.2011, 06:43 PM
Holmes does the same with the BRXLs with great effect
brian015
brian015's Avatar
09.05.2011, 06:55 PM
I used liquid electrical tape on one of mine - coated everything up to the heat sink - I used it in the snow a few times last winter with good results:
berserk80
09.05.2011, 07:08 PM
http://forum.rcdesign.ru/f74/thread2...ml#post2512515
