MMM Help!
yzinger02
yzinger02's Avatar
MMM Help! - 05.07.2012, 04:15 PM
Ok so my truck was running fine not too long ago. But i broke a shock shaft and 2 weeks later got it replaced. Now when I plug my battery in to my MMM It doesn't do anything. It doesn't give th usual tone and count off 6 beeps for 6s. The green light is flashing on the back of it, but it won't respond to radio signal at all (Including servo). It wasn't wet the last time I drove it, or overheated. Nothing out of the ordinary. My battery is at close to 25v, I discharged it a little and same thing. And then earlier my power supply or charger gave out when I plugged it in. So I'm not sure what to do. Please help!
Note: I got the esc closer to a year ago, not sure if its still under warranty.
bruce750i
bruce750i's Avatar
05.07.2012, 04:40 PM
Green light flashing is that your ch 2 trim not centered? Still don't explain servo? Is the Tx charged up? Maybe you squirted shock oil on something idk.?
Have you tried to recalibrate it yet?
yzinger02
yzinger02's Avatar
05.07.2012, 06:03 PM
Yes the Tx baths are fine and no I didn't get shock oil anywhere close to the esc. I guess ill have to see if I can recalibrate it but I don't have time tonight.
