My maxx
mikesauto
mikesauto's Avatar
My maxx - 01.10.2012, 10:55 PM
it's my tmaxx now brushless
mikesauto
mikesauto's Avatar
01.11.2012, 12:50 AM
2 VX G3 5400mah 2s MM2200KV XTM big block chassis 3906 trany locked in 2nd ue 8 diffs ue shocks mip cvds rpm arms & RPM Axle Carriers ue rear dog bone ofna dom front dog bone hc titanium skid
coolhandcountry
coolhandcountry's Avatar
01.11.2012, 09:50 AM
Got more pics from different angles?
Peace!
Country
Help support the
Rc-Monster
Buy here
Yep
Klausen
Brushless G-maxx
Klausen's Avatar
Yep - 01.11.2012, 11:31 AM
+1 on that.
mikesauto
mikesauto's Avatar
01.11.2012, 01:21 PM
back flip
pics
mikesauto
mikesauto's Avatar
Smile pics - 01.11.2012, 06:10 PM
pics
ID:	10223   Click image for larger version
ID:	10224   Click image for larger version
mikesauto
mikesauto's Avatar
01.11.2012, 08:49 PM
next mod is lst2 axles proline 23mm hex rpm revo carries
ID:	10226   Click image for larger version
ID:	10227   Click image for larger version
RC toy
Got Brushes? NOT
RC toy's Avatar
01.12.2012, 11:24 AM
Looks sexy lol. What size carrier bearings (both, inner outer) did you use with lst driveshafts?
01.12.2012, 01:41 PM
I was gonna ask the same thing- every guys that has done the LST cvd upgrade has had to run odd-sized bearing or shim them to make them fit correctly- did you have to do anything special as such?
mikesauto
mikesauto's Avatar
01.12.2012, 02:15 PM
big hole is 24.5mm I used two 15x24 and alum tape. small end is 15mm now 5/8 so 16x8mm fits good and tight I'll try to post some better pic of how I did it later
Kcaz25
Kcaz25's Avatar
01.12.2012, 04:37 PM
Did you have to drill new holes in the axles? Nice truck BTW.
mikesauto
mikesauto's Avatar
01.12.2012, 06:17 PM
thanks Kcz25 looks like I can run it with some shims (3mm) or small spacer or drill new hole still in the works
nylon washers 5/16
mikesauto
mikesauto's Avatar
nylon washers 5/16 - 04.16.2012, 04:30 PM
nylon washers 5/16 + 1 8mm shim
ID:	10311   Click image for larger version
ID:	10312   Click image for larger version
pics
mikesauto
mikesauto's Avatar
pics - 04.16.2012, 04:40 PM
got the washers fror hardwear store
ID:	10314   Click image for larger version
ID:	10315   Click image for larger version
painted my cage and fixed some bad welds
mikesauto
mikesauto's Avatar
painted my cage and fixed some bad welds - 05.24.2012, 11:55 AM
and put lst 2 axles on the back hard to see but it's an inch wider in the rear
ID:	10350   Click image for larger version
ID:	10351   Click image for larger version
