Should I? castle 1717 heli motor 6mm shaft
brushless losi
RC-Monster in process
Should I? castle 1717 heli motor 6mm shaft -
11.13.2014, 08:19 PM
Just won 1717 motor green can 1500kv but it is for a heli with 6mm shaft how do I make it work or is it even worth it (for xxl2 lst)
brushless losi
Find all posts by brushless losi
2
11.13.2014, 09:02 PM
Could of choices
- 6mm mod 1 pinions
- 8mm mod 1 pinions and bore reducer
- grind shaft to 5mm (search and a couple of posts on how to do this)
Find all posts by Arct1k
3
brushless losi
11.13.2014, 10:26 PM
There's sum holes in it for helis.
Should i plug or leave open just gunna run through grass and cement
If I should plug em up what is the best way
brushless losi
4
brushless losi
11.13.2014, 10:29 PM
Also what material pinion should I get I kno 25t is what is everyone runs but what is a strong material
brushless losi
5
11.14.2014, 07:44 AM
I used the alum tape from pipe ductwork to cover up mine.
6
brushless losi
11.14.2014, 04:35 PM
Arct1k did u hav ne problems what esc and car r u runnin
brushless losi
7
11.14.2014, 05:58 PM
I used it with a MMM and no issues
8
brushless losi
11.18.2014, 03:12 AM
arct1k have u used the 8mm mod1 with bore reducer (does it hold up well on 6s)? i could not find 6mm n e where
brushless losi
Hybrid Mode
Switch to Threaded Mode
5 : Excellent
4 : Good
3 : Average
2 : Bad
1 : Terrible
