Thread Tools Rating: Thread Rating: 21 votes, 4.81 average. Display Modes
XO-1 spur-to-pinion adapter that includes the "Cush Drive"?
Dr_T
Dr_T's Avatar
XO-1 spur-to-pinion adapter that includes the "Cush Drive"? - 11.22.2014, 05:38 PM
Hi guys,
Maybe I'm going a bit overboard here, but I was wondering if you guys think it would be possible to make a spur-to-pinion adapter for XO-1 spurs by mimicking the alloy part of the "Cush Drive" as the mounting part for the motor shaft. If that alloy part (think it's called the "Cush Drive Key", Traxxas part no. 6465) would be replaced by a custom CNC-ed part that can be fixed to the (8 or 6 mm) motor shaft with a set-screw, then the whole Cush Drive function would even be intact, which sounds great to me for running with a center spool. Possible concern might be the thickness of that gear mount assembly though -whether that would fit on standard 20mm shaft lengths- and possibly the weight.
Reason I ask is I'm looking for ~50T size mod 1 pinions. I know they exist in steel, but I think they might get too heavy. Also, I want to see if I can avoid steel-to-steel gearing; given the pinion will be paired with a much smaller 34T spur, I think it makes most sense to have the pinion (biggest) in plastic/composite/delrin and the spur (smallest) in steel, or even both non-steel.
Any thoughts?
If anyone that has access to XO-1 parts could post the thickness (and weight?) of the of the spur-mount assembly, I would be very grateful.
EDIT:
Could it be as simple as just tapping a set screw hole in the cush drive key :D? Does anyone know the diameter of the center hole of the key?
Lizard
Lizard's Avatar
11.23.2014, 06:56 AM
Sounds like a good idea and should be possible. I can slide the Cushdrive right over the shaft of the Turnigy motor :)
Hole is 6mm and I would say there is enough material to bore it out to 8mm if needed.
Pin diameter is 2.5mm. Width of the whole assembly is 21mm, but the bearing seat on one side could be cut-off, then it would be 16mm.
Cushdrive assembly (without shaft) with 46t spur is 28g.
For comparison:
35t Kershaw 5mm spur is 52g.
34t XO-1 spur is 36g.
Aluminum spur adaptor with 36t Revo 3.3 plastic spur is 14g.
Dr_T
Dr_T's Avatar
11.23.2014, 11:33 AM
Thanks for the detailed response Lizard! Much appreciated and very helpful, hurray for the 6 mm shaft :). Ordered 2 sets and going to see how it works out. Looks like I need to do some reading on how to tap threads with no tools :D.
Does anyone have any thoughts on running plastic-on-plastic gearing? Or better go with plastic-on-steel?
Lizard
Lizard's Avatar
11.24.2014, 07:06 AM
Cool. Do you have the Kyosho already? Looking forward to see a thread about it :)
Dr_T
Dr_T's Avatar
11.24.2014, 06:19 PM
Yes, figured I deserved an early Christmas present:
Proper powerplant mock-up:
Gearing options:
Will put together a thread soon :).
Dr_T
Dr_T's Avatar
12.04.2014, 11:06 AM
Still work in progress, but thought I'd throw in some pics to show feasibility.
Lizard
Lizard's Avatar
12.04.2014, 02:58 PM
Sorry, I have nothing nice to say :)
The CFK plate will act as a heat insulator, the motormount also seems to be optimized for worst possible heat transfer ;)
I think you could achieve way better heat transfer to the chassis with an aluminum plate and a motormount that has a larger area touching the chassis.
IMHO it's unecessary thick for onroad use, wasn't it made from 7075 T6?
Better would be 2mm (or something like that) thinner, but with the whole length touching the chassis and an additional screw to the chassis on the motor side.
Dr_T
Dr_T's Avatar
12.04.2014, 03:40 PM
No problem Lizard, your feedback and insights are greatly appreciated. And you are right :). I will just have to compensate with some big-ass fans :).
The motor-mount is basically a 1717 mount design, customized on my request to fit a 56 mm can. I did not explicitly take heat-transfer into account in the requirements I set, so I don't blame the maker. Ideally, I would have liked to see a bit more material covering the front endbell too, but this is how it came out. The fact it's so thick does mean it has a little more thermal capacity by itself.
The CF plate is not part of the motor mount design, but my own creation; it was necessary because I overlooked the clearance required for the rear endbell screws... Opted for a spacer instead of cutting another slot in the chassis for the screw, so I could also close up the chassis holes around the gears (they annoy me and I want to see if I can run all plastic gears, so I need to keep stones out as much as possible). An aluminium spacer is a good idea, might make one later.
I am really curious how the Turnigy motor will hold up at such high gearing, and I'm a bit worried about cogging. Did you try out yours already?
Lizard
Lizard's Avatar
12.04.2014, 05:02 PM
Couldn't motivate myself to work on the XO-1 yet and still need to order a new rear axle carrier for it. I guess it will be next year until I try it out.
What spur to pinion adapter did you get?
I hope the plastic/plastic combo holds up. Perfekt solution then IMHO. Very lightweight, no diff, but still some 'give' because of the cushdrive. And cheap compared to Kershaw pinions if you need to try out different combinations.
Regarding the endbell screw: You could use a set screw with blue threadlock. Would be flush with the can then and should hold up. At least that's how my TP5670 came.
Dr_T
Dr_T's Avatar
12.08.2014, 10:37 AM
That's a great idea, thanks! Actually feel a bit stupid for overlooking that... and I was so proud of my heat-insulating-motor-mount-spacer-creation .
The spool adapter for mounting the Traxxas spurs on the 6 mm Nitro tranny shafts is made by the same guy that did the motor mount and battery tray (don't want to be rude towards Mike, so I won't link to them here - I started a preliminary build thread with some more info at the other place).
The idea of tapping a set-screw hole in the cushdrive key is a bit on hold right now. The thing appears to be made of steel, there is just so little material and contact surface (4.5-5mm) compared to a normal pinion (6-9mm) - see pic, and I don't even have a drill-press (yet), let alone the skills to tap a tiny 2-2.5 mm thread in such a small steel thing. So as a plan B, I ordered a bunch of XO-1 29T and 34T pinions (super cheap at amain with their $2 intl shipping :)) and I'm going to try and dremel a pinion into the shape of the key, so I get a cushdrive key with a regular stable pinion base and set-screw. If successful, I'll grind down the shaft to 5 mm.
Lizard
Lizard's Avatar
12.09.2014, 02:22 PM
Dremeling a spur until it looks like the drive-key? That's ambitious :)
Where will the base fit then? I think there is no space inside the spur assembly (?)
Maybe make a CAD drawing and have it made by some CNC service. An M3 screw in a 4.5mm wide drive-key should be no big problem I think. The hole would have to be 2.5mm, that leaves a mm on each side. Even M4 could be okay considering that the drive key is 5mm wide near the center. 3.3mm hole would leave 0.6mm at each side at the top and 0.85mm near to the center. But that would probably require good material (not brittle and also not soft). Or use M3.5, but screws and taps are hard to find for those.
Or maybe go to a local machine shop or something and have them drill a hole into the motorshaft so that you can use the pin to mount it.
Dr_T
Dr_T's Avatar
12.17.2014, 05:00 PM
Haha, yeah, sounds more like it has disaster written all over it... you're right, I think I should just drop by a Kfz Werkstatt here to see if someone can tap a M3 hole in it. Comparing the contact area to a regular pinion, together with the small set-screw, just doesn't give me a very comfortable feeling yet, and I'm worried it'll be too wobbly, given the shaft won't reach the hole in the 2nd plastic end-cap.
I'll keep the CNC service in mind, thanks, didn't even know those existed. As another backup plan for if the whole Cushdrive plan fails, I ordered the OFN40760 Center Gear Mount. It has a 8 mm bore, so needs a reducer (or 6 pole TP motor :)), but Ofna has 44T-49T plastic spurs to go with it, so it should still be nice, light and cheap. Also have a $10 30T 6mm bore pinion (steel, 82g...) on the way from aliexpress, which I could use as a spur on the GT2 tranny shaft. Increases gearing options a bit: 49/30 (max Ofna) gearing would yield 112 mph no-load and 54/30 (max Cushdrive) 124 mph - no idea whether the motor will like that though.
Also haven't decided yet on ESC. Still attracted to XL2 to keep the door to 8S open at later point.
Dr_T
Dr_T's Avatar
03.03.2015, 06:41 AM
Finally tried preparing the Traxxas XO-1 cushdrive key for use as spur-to-pinion adapter, but wasn't very successful...
With a lot of effort I managed to drill a 2.5 mm hole in it (HSSE Cobalt drill), but then it cracked when I tried tapping the M3 thread (at about 1/3rd in). The material is extremely hard and it took very long to drill the hole, maybe because of that the hole needed to be a bit bigger diameter for the thread to be tapped?
Lizard
Lizard's Avatar
03.20.2015, 05:13 PM
From what I know, 2.5mm is the right holesize for an M3 thread.
Is the tap high quality? If it took a high quality drill to make a hole, maybe the Traxxas material is just too hard and/or brittle?
You could try some very high quality taps (those with 3 different ones that have to be used after another) but that's gonna be expensive and probably not worth it given the uncertain outcome.
Crap. Sorry that it didnt work out.
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
03.21.2015, 10:55 AM
You definitely need a tap specifically for hardened materials, but the hardened cast parts generally don't respond well to re-machining operations. You may have some luck if you cheat a little on the drill size(stuff is hard, so it won't likely pull the thread even if you drill a little bigger). Carbide tools and lots of lube!
Tags
adapter, cush drive, spur to pinion, xo-1
