My D8Te w/RCM Conversion
nastety92
My D8Te w/RCM Conversion - 05.02.2011, 08:38 AM
Here is my D8Te that I'm almost done with.
I have a few small things to finish and clean up. I bought this as a roller locally and it was in fairly good shape overall.
It has;
RCM Conversion kit
Tekin RX8 ESC w/2000kv motor
XP 1015 Steering Servo
Spektem tx/rx
The RCM conversion kit is really nice. It installed so easy and hid all of the wiring as much as possible.
Can't wait to start driving this one, I should have it out and about later on this week.
Let me know what you think,
Nick
Tamiya TRF801Xt-e
ZippyBasher
8th scale Stunt-Driver/Mechanic
ZippyBasher's Avatar
05.02.2011, 04:03 PM
Nice!
I just finished my D8Te and test drove it yesterday! Fun Car, Very Quiet and smooth. Whats your gearing? I setup mine as follows:
MMM
CC1717
6s Zippy
18/50 Crimefighter LPR and I may up this to 21/50
The car is on rails. Very easy to drive.
Can you tell me what that front bumper is? I have seen some of them But I cannot recall the name of the company that makes them...
Maxx - FLM, MMM, CD Med.36x706s
Raja - FLM Ext. MM, 1512, 4s
SC8ight - MMM, 1520, 6s
D8T - MMM 1717 6s
My OVERPOWERED Rides "CLICK"
Like Playing Cards? Cut-Throat Rummy "CLICK"
bdebde
That's All Folks!
bdebde's Avatar
05.02.2011, 11:12 PM
Looking good!
I need to give mine a tune up for the summer race season.
Bumper looks like a t-bone racing bumper.
nastety92
05.03.2011, 08:25 AM
Thanks for the compliments guys. The bumper is a T-Bone bumper. Right now this will be more of a basher for them. If I do go to race it I will probably take the bumper off, we will see.
Right now the gearing is the last thing I'm doing, along with hooking up the steering.
I think I'm going to start with 16/50 (if 50t is the stock gear thats in there). Then I will see how that goes and go from there.
Nick
Tamiya TRF801Xt-e
nastety92
05.05.2011, 05:16 PM
I got the D8T up and running last night/ this morning. Everything looks good so far.
One thing I did notice was the spur and pinion gears being fairly loud. Is this normal with a 1/8th electric conversion with metal gears?
Is anyone running a plastic spur on there D8 or D8T?
Other than the noise it is all working out well. Everything worked the first time hooking it up, esc programmed on the first try and it was all really easy actually.
I just need to wait for my Tekin hotwire to come in then I can start driving it.
Does anyone have a good starting point for programming the RX8?
Thanks,
Nick
Tamiya TRF801Xt-e
nastety92
05.06.2011, 02:11 PM
I am trying to determine a starting point for my D8Te. Would this work and be fairly safe to bash with on 4s?
Differential Ratio: 4.3
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 50
Pinion Tooth Count: 14
Total Voltage: 14.80
Motor KV: 2100
Tire Diameter (inches): 5.8
Tire Ballooning (inches): 1.00
Motor Current Draw: 140
Motor Coil Resistance: 0
Spur/Pinion Ratio: 3.57 : 1
Total Ratio: 15.35714 : 1
Tire Circumference (inches): 24.5 inches (622.41 mm)
Rollout: 1.60:1
Total Motor Speed: 31080 RPM
Vehicle Speed: 46.96 mph (75.44 km/h)
Effective KV Value: 2100
KT constant: 0.64 oz-in/A
Motor Torque: 0.47 ft-lbs
Final Torque: 7.21 ft-lbs
Final Power: 2072 watts (2.8 HP)
Then this is what I would use on 5s, does this look good?
Other Ratio: 1
Pinion Tooth Count: 12
Total Voltage: 18.50
Motor KV: 2100
Spur/Pinion Ratio: 4.17 : 1
Total Ratio: 17.91667 : 1
Rollout: 1.37:1
Total Motor Speed: 38850 RPM
Vehicle Speed: 50.32 mph (80.83 km/h)
Final Torque: 8.41 ft-lbs
Final Power: 2590 watts (3.5 HP)
Thanks for the help,
Nick
Tamiya TRF801Xt-e
gtxracer
HOOH HUAH HOOH! Aww Baby!
gtxracer's Avatar
05.11.2011, 09:44 PM
I just need to wait for my Tekin hotwire to come in then I can driving it.
Thanks,
Nick
I used Kyosho plastic spurs but all of them were eaten alive within a run or two. Don't bother unless you're racing or the sound starts to really bother you AND you plan to run the mechanical brakes.
Good call on Mike's center diff plate, I told you that thing is a must!
Your gearing and everything looks pretty good. Give it a run and after a few passes check the temps. As for the Rx8 setup, start with 40% brake power and go from there. Oh and use FWD/DEL, it's forward with brake but a delay between brake and reverse.
:D
JayJ
08.20.2011, 03:43 PM
Nice D8Te there fella, makes me want to get my NIB D8T converted but to many RC projects on the go at the same time!! lol
nastety92
06.05.2012, 07:39 PM
Here are a few updated pictures of my D8Te.
Nothing new under the hood, just a new body and a few new sets of wheels.
Heres the old body. It's the original nitro body with the holes filled in with tape. Still holding together. I run this one at the beach also.
Let me know what you think.
Nick
Tamiya TRF801Xt-e
nastety92
06.13.2012, 09:37 PM
Just got done putting a CC 1520 in the D8T. Just need to wait until tomorrow for the loctite to dry and to program the esc. Then we will be off and running.
Pics in the morning.
Nick
Tamiya TRF801Xt-e
nastety92
06.14.2012, 07:23 AM
Here are some pics of my new seteup.
CC 1520 1600kv
Tekin RX8
14/50 gearing
5s 20c Zipp Lipo
The 1520 looks pretty big next to the T8 2000kv.
I still need to shorted the motor/esc wires and program the RX8.
Can't wait to see what this new motor can do.
Nick
Tamiya TRF801Xt-e
freddy
06.14.2012, 10:36 AM
the 1520 is insane, i use it on my d8t and it is almost to much. its lika rocket. i have to be carfull when driving ore im just gonna melt the center diff.
freddy
06.14.2012, 10:37 AM
it is best to use 6s ore more and bullet connectors.
nastety92
06.14.2012, 10:45 AM
What is your setup Freddy?
Gearing also would help a lot.
Thanks,
Nick
Tamiya TRF801Xt-e
freddy
06.14.2012, 10:52 AM
Thanks,
Nick
im using the same spur gear as vorza, gonna check the exact tooth of the gears tomorrow.
