BL Terra Crusher "Electrified Crusher"
blasterak
BL Terra Crusher "Electrified Crusher" - 06.03.2006, 03:04 AM
Hey, I am new here but been browsing this site for months. I recently picked up a terra crusher and nitro evader for an awesome price(traded the evader for a XX4 WE:027: ). They both only needed a few things to get them running. But I really hate nitro so I decided to turn this into a BL monster since I never seen it done w/ a terra crusher. I have an e maxx and this thing is built alot better and should handle better and take wrecks better. Anyways my plan is to sell all the nitro crap to fund this. This is what I'll need to do:
Custom chassis- Any ideas on design and material? must holds 16 cells, fit E maxx tranny, strong/light, use a normal size servo instead of the huge one and have plenty of room for electronics
E maxx tranny-(already have, stole from my maxx)custom mount it to the steel driveshafts that come w/ the crusher, get a G maxx single speed conv. and steel idler and later a strobe slipper.
Suspension- Lower it so the arms are parallel to the ground and dremel away the unneeded material on the arms and what not, possibly get Racerx shocks, proline shocks, or run the four stock shocks w/ thicker oil.
Tires- bowties on velocity rims (already have, stole from emaxx)
Body- Crowd pleazer or Ext F350 painted pearl blue and silver and white accent w/ some kind of lightning designs on it and a Dpp wing mount w/ mugen wing ( I live really close to DPP racing up here in alaska)
LAST but not least the motor and ESC
??? what set up should I run to power this beast? I want something affordable, fast (40+mph, and torquey. Not to powerful where I will be constantly breaking parts want a trusty reliable system. My main idea is to make this a racer and a basher too and just for the shits and giggles. Let me know what you think and the motor and esc recommendations too. This will be one of my first BL projects, I got an FLM pede I am gettin a BL system for soon. This project may take awhile to get done ($$)but it will get done.
Pics:
squeeforever
squeeforever's Avatar
06.03.2006, 01:05 PM
Welcome to the forums! Thats a very good truck to start with. It looks as though it will be a very straight forward and simple conversion. As for chassis, with those braces, I would choose carbon fiber. Its light, sweet looking, and out of the ordinary. As for BL setups, I would choose something like a 8 or 9XL and either a Warrior 9920 and a Quark 125 controller. What motor depends on what you want, runtime or speed or both. As for shocks, I think you would like the Powerstroke shocks. With the by-pass shocks, I think it would help dampen it with such a big truck.
boss 302
06.03.2006, 03:28 PM
that definately looks like a good truck to start with.
i would go with the 9xl because it would give you good runtime and power on 16 cells. it also wont heat up very much if geared properly. Either the 9920 or quark would work well with this setup
blasterak
06.03.2006, 03:34 PM
Thanks and is carbon fiber pretty easy to work with? What kind of tools do you need to cut it? I got access to a mill and lathe so I was going to do the main chassis in aluminum and make battery holders like on the G maxx chassis, but out of lexan and lower them like on the G maxx (and use the CF G maxx batt straps) so it has a Low COG. But I would really like CF but is it hard to work with? and where online can I buy it? Thanks for the help and I think ill go with the 9920/9XL sounds pretty damn good and its pretty reasonably priced.
Dafni
Dafni's Avatar
06.03.2006, 04:02 PM
Hey, welcome to the family! All the power to you, nitro conversions rock! And this truck looks like a good platform to start with.
One thought: How about, instead of the obvious E tranny route, a buggy centerdiff? From my experience I can tell you that centerdiffs make the sick BL power much more handle-able (if there is such a word?). For racing, I would go centerdiff!
DAF
blasterak
06.03.2006, 05:36 PM
DAF
Exactly how does that work? I never heard of doing this, sounds interesting, so you just use a center diff from a buggy and mount the motor near it and have it turn the spur gear on it? You happen to have a pic and how to or of how this works? Sorry for all the q's but never heard of doing this. EDIT: I found some pics and get how it works now but the thing is w/ this Crusher they use driveshafts and output yokes instead of dog bones and all the center diffs I see run dog bones, There is no way that I can think of to convert the center shafts to dogbones because the center shaft is splined at the end where it goes into the f/r diffs , so I dont see that happening really. Any ideas? Also would a 9L be able to power this decently? Go atleast 40mph? and decent runtimes?
boss 302
06.03.2006, 09:06 PM
a 9L would not be able to hanlde it to well and would heat up quick.
also a center diff wouldnt be to hard since you can have custom dogbones made for it. a center diff will be much better than a tranny imo.
squeeforever
06.03.2006, 09:28 PM
Actually, a center diff might not be possible because of the splines on the pinion gear in the diff. I have never seen a truck like that. If you have access to a mill and lathe, you can probably make it work though.
blasterak
06.03.2006, 09:37 PM
Yeah as you can see it is a splined axle so I dont know if anyone can make dogbones like this. I think I'll just do the tranny, I got the output yokes on these drive shafts to fit on the E maxx tranny out put shaft, just needed to drill a slight larger hole in the output shaft.
http://i35.photobucket.com/albums/d1...k/000_1122.jpg
coolhandcountry
coolhandcountry's Avatar
06.03.2006, 09:53 PM
That looks like going to make the conversion a little harder. For the size of the truck I would go with a xl motor. If you want a L motor I would go 10L for 12 cells. Should keep the heat down but don't think it is going to get the speed you want. Some of the center diffs had removible cups on them. I got one off ebay. It was for a ofna mbx i think.
Peace!
Country
Help support the
Rc-Monster
Buy here
blasterak
06.03.2006, 10:41 PM
Ya I am going w/ the tranny, I see you have one listed on Ebay, I may place a bid on that, its already built and all but one question are the output shafts on that tranny the same length as a normal 2 speed, in otherwords do the output shaft(center shafts connect to it) on that tranny stick out just as far as on a stock tranny? This is important because if the output shafts is shorter than the driveshafts will be to short to reach the tranny. Also will that wanderer 9xl you got listed worked pretty good for this too?
Gustav
Gustav's Avatar
06.04.2006, 12:28 AM
Yup,output shaft is exactly the same as on the 2-speed.
blasterak
06.04.2006, 01:18 AM
Alright cool, thanks for all the help you guys have given. I am about to tear it completely down and clean it, inspect it and replace broken/worn parts. Get all the nasty nitro gunk off of it, relieve its dirty sins :mad:1
coolhandcountry
06.04.2006, 08:46 AM
What is good to get that oil gunk from nitro off of the plastic? It don't like to come off. It acts like it is in the pors of the stuff.
Peace!
Country
Help support the
Rc-Monster
Buy here
blasterak
06.04.2006, 01:04 PM
I dont know but I got this "Castrol Super Cleaner Degreaser" that I am going to try, I always use it on my quads to get off oil and dirt and gunk off of the engine. I got it all in pieces now, looks like one of my bulkheads snapped. Thinking of gettin aluminum ones but want this to be light.
