Originally Posted by Serum
Very nice!
Is it a 4S setup?
Two Orion 4800's run in series, I'd like to try the Maxamps 8000's now that I have the cooling figured out.
If I drive the outside oval as fast as my limited skill will alow with no stops or crashs it runs 13 minutes on the nose. Running the outside is what taxes your cooling. Runnig for 13 minutes straight in 90+ degree weather,
while on either full throttle or the break tends to heat things up a little. If I mix it up (do the jump and the other center legs of the track) still running as fast as I can with no stops I get just over 15 minutes.
