Connectors or Direct solder for esc & motor?
rkman
rkman's Avatar
Connectors or Direct solder for esc & motor? - 10.22.2005, 12:40 AM
Do you guys use connectors to connect your motor to your esc or do you solder them directly?
If you use connectors which are preferrable? Power poles?
I've only had experience with Novak BL so I haven't had to make the connection between the motor and esc.
Thanks in advance, this site rocks.
