aint tough enough
capitol
aint tough enough - 10.06.2006, 10:11 PM
Well, I was bashin and thrashin with da nitros :028: and out flies my battery.
What the ... :035:
Its my first casualty after many long hard hours of running.
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
10.06.2006, 10:30 PM
seen that happen alot...try doubling up the straps..and that should help you
Bl E-REVO
Quark 125b
Castle Creations-Neu 2200kv motor
((2s2p)(4s)
7800mah 7.4v Lipo Pack
E-Revo 1/8 scale Hyper 7 CD
http://www.rc-monster.com/forum/show...1&goto=newpost
  Send a message via MSN to sjcrss
squeeforever
squeeforever's Avatar
10.06.2006, 10:55 PM
You might want to put something around it as well. It will prevent it from flying out.
capitol
10.06.2006, 11:06 PM
Yup, Im thinking the gorilla straps and the emaxx straps crossing the battery will work.
go4gold
mod emaxx
go4gold's Avatar
10.07.2006, 12:44 AM
possibly a piece of angle along the side to prevent the battery from falling out if the strap gets loose
So many toys and so little time
Serum
Serum's Avatar
10.07.2006, 01:57 AM
like sjcrrs suggests;
Use two gmaxx straps over eachother. The slots in the flm chassis are deep enough to keep the cells in. If you just put two straps over eachother (one from front to rear, the other from rear to front) you should be fine.
Tazz
Custom
10.07.2006, 10:59 AM
Actually the gorilla straps are vary strong it is the fasteners that are the problem. Because the fasteners are round it puts all the stess in one spot instead of accross the entire stap. I use a small peice of "L" shaped aluminum on the top instead and I have never had a problem.
smhertzog
Breaker of all that is Stock
smhertzog's Avatar
10.07.2006, 02:17 PM
Naughty boy you're asking questions about an FLM chassis on the Gorillamaxx forum. :027: :018: :027: :018:
You might want to put a thin piece of high density foam or sticky back foam strips between your batteries and that sharp metal frame. BZZZZT POP!!:035:
Never fight an ugly man..... he has nothing to loose
capitol
10.07.2006, 02:25 PM
not true. i didnt ask a question about the flm chassis. my gorilla strap tore and i posted it in the gorillamax forum
smhertzog
smhertzog's Avatar
10.07.2006, 02:26 PM
Good one I missed that:018:
Darren
10.07.2006, 02:36 PM
smhertzhog - I think it was because it was a Gorillamaxx strap he busted.
I've broke mine many times, I made some of my own version of the short bits using a bag strap and the gorillamaxx plastic recatangle bit. Seems to hold up better.
Posted too late :005: .
Serum
Serum's Avatar
10.08.2006, 04:14 AM
I currently looking for some car seatbelt to make some kind of bulletproof battery holders. I've got an idea in my head that needs to be done..
neweuser
neweuser's Avatar
10.09.2006, 02:01 PM
Actually, you could use straps from a car seat for babies, those are strong too, and about the right size. You just would need to fasten them like the gorillas.:027:
neweuser
neweuser's Avatar
What the ... :035:
I've done that with about 4 straps! Dump the round fasteners as suggested and use something padded and flat.:eek:
