How often does this happen?
bluonyx
How often does this happen? - 09.18.2006, 12:33 AM
After my bashing cleanup, I noticed this on my G2R. I kind of took a jump at the wrong angle and landed on the left roof side.:eek: I would have never expected one of the X braces to give. I thought the servo plate or lower chassis plate would bend first.
jocktheglide
09.18.2006, 02:50 AM
almost normal to me anyways I have 3 gorilla chassis not if you take a hit you will get bent even on the X chassis my got dented one time. I try to put as skid plate under to try to protect my chassis plate or anything else just me though.
Flossin22s
09.20.2006, 02:15 AM
Check to make sure you didn't tighten the tranny mount screws too tight! I did that on my E-Maxx with the G-Maxx Chassis and the X-Brace looked a little like that too!
Try loosening the screw to see if it was too tight...
bluonyx
09.20.2006, 11:23 AM
I loosened it up a bit and ordered a new Xbrace. WOW, I couldn't believe the cost of just one brace!
neweuser
neweuser's Avatar
09.20.2006, 11:34 AM
Yeah, that looks like a bad landing! Ouch. They are on the spendy side for just one. I too run the skids underneath as well. Also, make sure none of the screws on the bottom are too loose. Loose screws on the bottom can cause this as well.
