Brushless MBX5 MSR? Is this possible? -
09.25.2006, 05:07 PM
first post to this site, but an RC fan going on 5 yrs. Great site you have here and lookforward to reading and learning a ton...
Is it possible to convert an MBX5 MSR to a brushless Truggy? Running nitro near is getting incredibly difficult.
Thanks
09.25.2006, 06:17 PM
First off, welcome to the forums! The Mugen truggy would be my first choice to convert. It will make a fine conversion. Go with something like a Quark 125 and a Neu 1515 for it. How many volts do you plan on running?
09.25.2006, 06:23 PM
Anything is possible...
09.25.2006, 08:43 PM
i haven't given that a thought yet. I have a buddy that works for HH so the quark or the mamba would be my first choices. Since I'm a brushless newb I not sure which would be best.
as for converting the MSR, what would i need? Just a new motor mount, spur and pinion? if anyone has a link to a conversion set that would be great.
My buddy runs the KD conversion for his Savage and loves it....
09.26.2006, 10:37 AM
And if you are planning on running 4S lipo, you can use the mamba-max as well! which is a cheap alternative to run the Neu motors on.
09.26.2006, 01:59 PM
The Mamba Max can handle 4s with no problems?
I thought I read where it handles 2s-3s Lipos.
09.26.2006, 04:39 PM
It can handle 4s Lipo, but you need to use a UBEC or a receiver pack. The internal BEC is rated at 3s Lipo max., and so that's the main reason why Castle Creations says rates it like that.
09.26.2006, 05:52 PM
they where initially meant for 4S as well.
10.02.2006, 10:43 PM
does the mm have a cutoff set for 4s lipo?
TEAM FUSION
10.03.2006, 01:01 AM
Yes... it has a 12.0v setting.
You can actually use the software to make the cutoff whatever you want... so if say 11.9v sounds better to you.... there you go.
10.03.2006, 01:14 AM
It should be noted that the custom cutoff voltage can only be accessed with the computer software. If you only do manual programming, you are stuck with the canned 3.0v/cell cutoff.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
