A123 M1, 7XL, Quarky E-Maxx project
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
A123 M1, 7XL, Quarky E-Maxx project - 12.03.2006, 07:18 PM
Hi there, im just posting the starting point for my BL emaxx project
Specs so far:
Fiegao 540C-7XL
Quark Monster Pro (integrated massive heatsink behind motor for cooling)
5s2p A123 battery pack
uBEC
HiTec 120oz/in servo
RD Logic Spikes tires on RD Logic rims
FastLane Machine diff cups
MIP CVD's, center RC-Monster CVD's
RPM suspension arms, and axle carries
ID:	2030   Click image for larger version
Name:	DSC05690 (Small).JPG
MetalMan
MetalMan's Avatar
12.03.2006, 09:54 PM
Your project will be interesting to me, considering I will also be using 5s2p A123 cells and a Feigao 540C 7XL in my Revo. But, I'll be using it with the Mamba Max.
Sylvester
Sylvester's Avatar
12.03.2006, 10:19 PM
Very nice start! Cant wait to see some pics when the final product comes to life! :)
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
zeropointbug
Z-Pinch racer
12.03.2006, 10:47 PM
Oh ya, for sure we can compare results. I just love it when i hear people using the A123 cells, it's the direction we need to go in. They are just simply better batteries.
The chassis will be a Gorrilla Maxx style design somewhat. The upper chassis will be 6mm aluminum machined (you can see a rough sketch in the pic) that will screw to the bottom chassis plate (also machine lightened), in combination, i honestly think it will be THE most rigid/durable chassis to appear in the western world ;)
I plan to use 7075-T6 aluminum Alcad, the tensile strength of this grade is 85,000 psi, common 6061-T6 Alum is about 45,000 psi. Very high strength indeed, also very high fatigue resistance, which is needed too.
starscream
RC-Monster TQ
starscream's Avatar
12.04.2006, 02:30 AM
I used my A123 6S1P setup at the track yesterday. I would have used them racing but they dump right around 15 minutes so I didn't want to chance using them in the 15 minute Main. I am running 6S1P and they don't give me the punch my 5S1P Kokam 20C 3200mAh cells do. My next project is 8S1P A123's with a 12XL. I'm just waiting for word on the esc. 8S1P should give me the Punch and run time I am looking for.
Ha Ha
zeropointbug
Z-Pinch racer
12.04.2006, 03:01 AM
Oh yah, the A123's you NEED to double them up, you are working them too hard running single cell (it's only 2.3Ah), doing 2p you get 140 amp cont. plus more punch from higher voltage, and more than double runtime.
8s1p running a 12XL would be a monster for sure, but i think you are better off going 6s2p running a 8 or 9XL motor. Which I should have done... i should have got the 8XL running (i got 7XL) 6s2p pack. For more power and runtime.
starscream
RC-Monster TQ
starscream's Avatar
12.04.2006, 03:27 AM
I guess you can call me an efficiency freak because I'd rather get my runtime from higher voltage than running packs in parrallel. I guess I feel that if I'm going to add extra weight by adding cells, I'd rather run them in series and get the benefits from the higher voltage than waste the opportunity by running them in parrallel. 8S will significantly reduce the current needed from the batteries and boost my run time as well. 8S1P should get me well beyond the 15 minute mark for the Mains. 8S1P is lighter than 5S2P and I'd be willing to bet the run time won't be much different. I can't say for certain until I get the opportunity to actually test it. I'm waiting for the esc and I'll post my results. :017:
Ha Ha
Procharged5.0
Procharged5.0's Avatar
12.04.2006, 12:18 PM
Great project! Keep us posted on developements.
I'm considering 5s2p or 6s2p A123's as well.
Serum
Serum's Avatar
12.04.2006, 12:22 PM
You see zero, another person here who takes higher voltage over higher current, this is not for nothing.
Projects are always nice. But if it will be the strongest designin the west? you got the 32p gears that will fail on you sooner or later.
zeropointbug
Z-Pinch racer
12.04.2006, 12:31 PM
Serum, i am prob the biggest high voltage freak around, i was just mentioning to him my experience when using 1p or 2p. I've built a Tesla Coil, i'm sure you have no idea what it is or how it works, mine discharges at 750,000 volts @ 350KHz.
You can let the arcs stream off your hands with no ill effect.
What does 32 pitch have to do with anything!? Gears wear out, thats a simple fact 'Serum'. And when i say the best in the west, do you really think someone means it? Are you just looking for stuff to bicker about?
Serum
Serum's Avatar
About the diffcups; did you bought them already? i would not put my money on a 6061 cups, i would get a 7075 instead. the contact area of the shaft that holds the bevel gears presses real hard into/onto the aluminum, since 7075 is a harder grade, they will wear less fast.
Serum
Serum's Avatar
12.04.2006, 12:36 PM
No, you are absolutely right, i have got no idea what that is, now if you'll excuse me, i need to put someone on my ignore list..
You arrogant a-hole
zeropointbug
Z-Pinch racer
12.04.2006, 12:40 PM
Oh !? I'm an A-hole now? You know what, all i can do is laugh at ppl like you.
Serum
Serum's Avatar
12.04.2006, 12:43 PM
Go ahead, twist and turn your way around till you get your truth....
who the f do you think you are stating a thing like 'i'm sure you have no idea what it is or how it works'
Based on that i think you are an arrogant ass who thinks he knows it all..
Now get out of my way you little annoying prick.
Procharged5.0
12.04.2006, 12:51 PM
Guys! Come On!
Zeropointbug....relax a little. This is a friendly forum! We enjoy the company of and are friends with other members here. It's no competition. Leave the attitude elsewhere.
Serum has a point with 32P gears. Mod1's are stronger. Thats why I designed my new MAXX slipper with them.
