Interference
rc4x4nut
Unhappy Interference - 01.23.2005, 08:28 PM
Which creates more interence a brushless motor near a reciever or a brushless motor over the controller? The reason I ask is because I have the novak hvmaxx and wanted to use the gmaxx motor mount. However, the gmaxx motor mount would raise the 8 oz motor higher than using the stock emaxx motor plate. What do you guys think?
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
01.23.2005, 10:21 PM
Nobody says you have to use the upper motor mount position. Put the motor off to one side and it will be lower than the stock position. the tranny is already about a half inch lower. I usually put my motor on the opposite side as the steering servo, as low as possible. You may need to put the motor up one spot from the bottom position on the motor mount to make room for the speed controller.
rc4x4nut
01.23.2005, 10:50 PM
I was just thinking about the motor mounting position. Good thing I asked because I was going to mount the motor on the same side as the steering servo. Would there be any interference from the motor to the controller.
RC-Monster Mike
Site Owner
01.23.2005, 10:57 PM
You shouldn't get any interference. I would re-solder the motor wires so they are shorter and run directly to the controller (maybe on opposite side of the motor solder board). The Novak is a cluster of wires!
rc4x4nut
01.24.2005, 12:32 AM
Thanks. Yeah I am thinking of shortening the wires instead of trying to wrestle it around.
rc4x4nut
01.24.2005, 02:28 PM
Well I finally got my motor mounted to the side. However, I did have to slide the contoller to the side a little. I havent cut the wires yet since I doubt my soldering skills:M: One thing I noticed is that with the stock suspension sags a little due to the heavy motor. I used to be able to drop the emaxx from above my head (i stand 5'9") and the suspension would soak it up. Now if I drop it from just above my knee it will bottom out but not bad. Hopefully I cant fix all this when all my suspension components arrive.:cool:
RC-Monster Mike
Site Owner
01.24.2005, 02:42 PM
It is alright if the suspension bottoms out. That is what the skid plates are for. If you are a big jumper, then go to heavier oil, but for racing, the sweet set-up will usually bottom out on the bigger jumps, but soak up the smaller jumps and bumps on the track without upsetting the chassis.
rc4x4nut
01.24.2005, 02:46 PM
Thanks for the info. I am a hardcore basher turned racer and am still learning the tricks of the trade.
RC-Monster Mike
Site Owner
01.24.2005, 10:46 PM
Not a problem. If you need more setup help, let me know!
rc4x4nut
01.24.2005, 10:53 PM
I just got finished mounting the proline powerstroke shocks on the stock suspension. Full review to come soon.
RC-Monster Mike
Site Owner
01.24.2005, 11:01 PM
Cool. I am looking forward to the review.
Serum
Serum's Avatar
04.17.2005, 01:09 PM
Any news on the powerstrokes?
You had some time making a review...
here is a review from rcnitro.com
