rustler mod 1 gearing
rustler mod 1 gearing - 10.03.2007, 10:54 PM
I don't know if it will help anyone, but a monster gt 46 tooth spur will fit on the original rustler slipper (not xl-5) with NO MODIFICATIONS, allowing mod 1 pinions on 5mm shaft motors. If you do have an xl-5 you just need to switch the input shaft and slipper. That, a steel idler and vxl spec diff(#2381X) have kept me happily bashing for weeks in a stock tranny housing. BASH ON!
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
10.03.2007, 11:07 PM
That's pretty sweet. I didn't know about the MGT gears. If I hadn't already upgraded my slipper to the XL5 I'd probably buy one of those gears. If you have the XL5 slipper you only need to buy the Revo spurs. They're already a direct fit to that slipper. That VXL diff is a good idea, though. Or, you can get the FLM steel diff from Mike.
10.03.2007, 11:58 PM
If you mod the mgt spurs to fit the xl5 slipper you have the best of both worlds. The stock slipper sucks for a heavy/over-powered pede. I use the xl-5 slipper with jato spurs and 32p pinions and have not had a single problem. The mgt pinions just need the ctr hole enlarged to use the xl5 bearing, and 3 of the "peg holes" opened up to fit over the bolt bosses on the slipper hub, 2 minutes with the drill, at most!
