Jammin CRT Spur Options?
Sower
Sower's Avatar
Jammin CRT Spur Options? - 04.27.2007, 10:12 PM
So I have the Kyosho 46 and 44 tooth spur gears, but I'm wondering if there's any other options. I would really like to find a 54 tooth, or something around there. Any ideas? Thanks.
jnev
jnev's Avatar
04.27.2007, 11:37 PM
Well, as far as I know, Mike is in the process of making one, He originally made some delrin ones, but in the end, they didn't end up working. I think he also said that you can mod a 46t spur to fit as well.
nl12
nl12's Avatar
04.28.2007, 09:43 AM
using different diffs gives you better gearing as well, you can use the lsp ring ring and pinion. You can also drop the center diff a lot lower by using the cr buggy center diff mounts if you are using the 46 or 44 spur. Mike also sells an adapter for a 51 t spur pm me if you are interested in using a 51t.
Sower
Sower's Avatar
04.28.2007, 11:23 AM
Yep, actually the 46t from Kyosho that he sells in his store is a direct fit to the CRT diff. I have that one, but would also like a large one for some better gearing options.
Aragon
04.28.2007, 06:35 PM
I got a 56T made up for me out of delrin. It's for my CR conversion. I have yet to test it, but I don't imagine it not working.
Sower
Sower's Avatar
04.30.2007, 12:16 AM
Nice, let me know how it works when you get to test it.
