ok guys my nimh pack was runnin ok and then it just stops, i temp it and 2 cells were 190 degrees f and all the rest were 110 so im sick of these stupid packs with no run time and they dont give very good voltage so
im going lipo!!! YAY!!!
i want limh for my flm mamba pede with 5000 mah if theres one, or close, any recomendations??
and then i will have lipos for my cars but in the pede that i BASH HARD i need something a lil more stable//
i know chc runs these packs, and they do well.. so i want in lol
and last how do i charge them? i will get a super brain 989, and i dont know if i need a ballancer or not?
EDIT: will my mamba max 5700 kv motor handle the 3 cell limn? or no, or do i need a ubec? if i have to do the ubec or whatever i will just get the 2 cell one
you should adjust gearing and it will be fine.
lower tooth pinion or bigger spur, to compensate for the higher voltage.
your on 8 cells nimh, or not?
thats 9.6V, limn 3s is 11.1V
i'm kinda worried with heat, cuz your pede is on the large side for the MM motor. but yeah, test it with gears you got first.
sorry if i confused you, i was only trying to help.:002:
i run my mm5700 on 2s and with 4" tires.
i run 12.96/1.
