Setup help
E-Maxx King
Setup help - 06.28.2007, 01:12 AM
K Im going with the NEU 1y for sure. Now Im not sure on the ESC. Would a MGM Compro 160 amp, 16 cell brushless car controller. Its that one or the Quark. Unless theres another one. Now I heard that the Quark gets really hot. So with the heatsink and two 40mm fans, would that bring things down? I live in Texas and since its summer its getting about 90-100 unless it rains. Yes thats weired I know.:032:
For the gearing Im going to get Idlers and a ofna 51 spur. Im going to be running 40 masher, 40 series moabs, and the stock tires. This will be ran on 14 cells. Im a basher so I would want at least 43 mph.:005:
Now for durability, Will 3.3 axles hold well or will I have to get 3.3 cvds and RC Monster dog bones for the center. Will that hold? Gorilla maxx single speed maybe. I will have to see If first gear will be worthy.:028: Will I have to go will 1/8 scale HB diffs? Or will FLM gear work? Cause then Ill need FLM hybrids. Also do you think a revo would be a better choice for me? One day my car will be metal so?:032: Can this car be built like a tank? Im just a newb with a ton of Q? Man I wish someone with knowledge could move bye me. So FLM hybrids, FLM A-Arms. FLM Bulk braces, FLM Shock towers, FLM chassis, RC Solution Roll cage (red), and a some Integy shock. Could that survive a 10ft drop like off a roof? That would be cool to jump on and off my roof!
Guessing how much runtime Im going to get. How many amps and watts is this system going to be putting out?
Ryan King,
thx
mkrusedc
NeuMaxx
mkrusedc's Avatar
08.24.2007, 11:20 PM
Did you ever get this answered? I have alot of the same questions.
Thanks.
jnev
jnev's Avatar
08.24.2007, 11:56 PM
If you haven't, I can answer some of them. Let me know. I just dont' want to type a long response if you already know the answer, lol.
mkrusedc
NeuMaxx
mkrusedc's Avatar
08.25.2007, 12:04 AM
Thanks.
First if my MM cogs too much what is the next best Quark or MGM and which one?
Second 51t and 15 pinion. Will the gears mesh with a GMaxx tranny with the Neu 1515/f? If they will do you think that will run hot?
jnev
jnev's Avatar
08.25.2007, 12:11 AM
The MGM and Quark both have there weakness. The Quark can't run 6s even though it says it can, and it has overheating problems. But if you don't run 6s or plan to, it is a great choice if you can do the heat mod. I'll try to find the link for how to do it.
The MGM seems to have reverse/braking problems from what I hear. However if you don't use reverse or have it programmed, then it doesn't matter.
Which Neu are you talking about specifically? The one you have written in your signature would run great in an E-Maxx. I can't help with the gear meshing part as I don't have an e-maxx. Hope the previous info helped though.
E-Maxx King
08.25.2007, 12:32 AM
Ive learned alot so far. Im going to get the neu 1y. Unless the 1950/6 lehner (MM) is in stock??? lol I that pretty much everything?
Heres a list of the setup Im going to be running. (14 cells) I like the MM pc programing, but the quarks sleek design. Hmm???
Neu 1y $280.00
RCM Neu Endbell Cover $ 7.50
RCM Idler Gears $ 28.00
RCM 72mm Dogbones (2) $ 24.00 (Where do i get the drive cups?)
RCM Strobe Slipper Kit $ 32.00
RCM Ofna 51T Spur $ 7.50
RCM 1/8 HB Pro Diffs $130.00 (do I need bearings for the pinion gear?)
RCM Gold Plugs 5.5mm $ 10.00 (How Many Male And Females?)
FLM 1/8 Hybrid Bulkheads $140.00
FLM Bulkhead Braces $ 18.00
Kershaw Designs 22T 43mph $ 20.00 (Way Over Priced! Man that Gay)
UE Servo Saver Gen. 4 $ 84.00
Hitec HSC-5955 333oz $115.00
3.3 Knuckles $ 20.00
3.3 Turnbuckles $ 10.00
$1206.99
mkrusedc
NeuMaxx
mkrusedc's Avatar
08.25.2007, 01:00 AM
This is mine so far:
2 SPC matched and zapped IB 4200 7-cell battery packs
Gorilla battery straps
PowerStroke shocks
12 slipper pegs(waiting on a Strobe)
Traxxas wheelie bar
RPM suspension arms
RPM axle carriers
Traxxas 3.3 turnbuckles
Traxxas 3.3 drive shafts
Revo wheels
RC-Monster steel dog bone center shafts
Traxxas 3.3 gray bulkheads
Power Pole connectors
Futaba S3305 MG steering servo
Gorilla Max single speed transmission
RPM shock towers and body posts
RC-Monster steel idler
Neu 1515/1y/f
Strobe slipper
FLM aluminum diff cups with modified gear and 3 mm screws
Ofna 51t and ?? pinion
or
Associated MT 52t and 12t & 18t pinions
E-Maxx King
08.25.2007, 01:18 AM
Cool! I have the traxxas wheelie bar. But I heard you can run them one the flm skids!:( Mine will be A FLM Maxx one day. Will 43mph run to hot? Should I gear it to 40? I might start a micro rs4 drifter project.
E-Maxx King
08.25.2007, 03:39 PM
Update! Going with the 8xl just cause the MM! What gearing? 40? What size drive cups do I need for the rc-monster dogbones? 5mm, 6mm, or bigger?
RCM Centers $ 24
RCM Strobe Slipper $ 32
RCM Idlers $ 28
RCM BEC $ 37
RCM 3.5mm plugs $ 2.50
FLM 1/8 Hybrids $140
FLM Bulk Braces $ 18
HB Pro diffs $130
Hitec HSC-5955 Servo $115
UE Gen. 4 Servo Saver $110
Metel Servo Horn $??
MM ESC $137
Feigao 8xl (Finned) $ 90
$863.50
I this every thing?? What hinge pins? Traxxas?
mkrusedc
NeuMaxx
mkrusedc's Avatar
08.25.2007, 04:08 PM
I got the cups from Mike when I bought the dog bones so can't help you there but check out Brian's speed calculator for gearing options.
http://scriptasylum.com/rc_speed/_top_speed.html
wallot
wallot's Avatar
08.25.2007, 04:13 PM
they fit in MIP cups if you have 6mm shaft (tranny) or Hot Bodies, HPI Savage cups if you have 8mm shaft (1/8 diff)
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
wallot
wallot's Avatar
08.25.2007, 04:14 PM
one more thing - 1/8 diffs cups are longer so you will need bit shorter dogbones. Mike will make them for you
Radek
*EX-10 Eurus*
08.25.2007, 04:17 PM
It's too bad no one makes a CVD / adjustable slider hybrid. It would be nice to have the strengths of CVDs with the convenience of different lengths...
wallot
wallot's Avatar
08.25.2007, 04:27 PM
you can get metal sliders from ebay. my friend tried them on his smelly :) savage and they were trash so he went back to dogbones
Radek
*EX-10 Eurus*
08.25.2007, 04:28 PM
OK, so they should make good ones.
