Revo Gearing
bensf
Revo Gearing - 05.23.2007, 10:24 PM
I'm planning on getting a 15T pinion from Mike and was wondering whether I should get a 52 or a 49T spur? I'll be using a 8XL motor with 14 GP3300 cells. Thanks.
cemetery gates
05.23.2007, 10:34 PM
This is for a revo? AFAIK, the revo doesn't use 52-49 size spurs.
Do you have an e-maxx trans, stock revo trans, slipperential, other? I need more info please. :018:
GorillaMaxx360
GorillaMaxx360's Avatar
05.23.2007, 10:35 PM
it depends what you are going for more speed or acceleration.
05.23.2007, 11:05 PM
Yeah, with a Revo tranny, you are stuck with 36, 38, or 40T spurs. Then, if you have it locked into second, you can get the narrow, standard, or wide ratio gearsets for the tranny internals, which also changes the total ratio, but is a little harder to get to...
bensf
05.23.2007, 11:08 PM
It has an Emaxx tranny in it. I'm going to lock it in second. I'm leaning more towards the 49 for the higher top end.
49/15 16.01225 : 1
52/15 16.99259 : 1
I got those off of the RC speed calc.
05.23.2007, 11:22 PM
OK, if using the emaxx tranny, you'll probably be using a Mod1 gear, like the Ofna 51T spur? Most use that spur and then whatever they need for the pinion since the pinions are easier to change out.
bensf
05.23.2007, 11:32 PM
Is there anyway to use that without getting the strobe slipper? Could I use the slipper on my revo tranny?
05.23.2007, 11:47 PM
Well, you can, but it's gonna take some modification of the shaft. Someone here has done it, but I can't recall who it was now...
bensf
05.23.2007, 11:59 PM
It looks like I would have to drill a hole in the shaft to get the pin to go through. Where could I get a strobe slipper?
05.24.2007, 12:13 AM
Well, I would normall say here, but it seems they are out of stock...
bensf
05.24.2007, 11:09 AM
This is the same thing. right?
Serum
Serum's Avatar
05.24.2007, 11:16 AM
Yes, it is the very same.
