Lipo for 3 different Emaxxes
krunk
Lipo for 3 different Emaxxes - 05.24.2007, 01:25 PM
I want to convert to Lipo without breaking the bank.
Need Lipo/charger/balancer recommendations for my E's
Setup 1: stock
Setup 2: 1930/5 Lehner with a BK19150
Setup 3: Duel Hacker B8s / schulze 66ce
Option 1: 4S for the stock and the Lehner setup and (2) 3s for the Duel setup
Option 2: Sell the duel setup?
Option 3: ?
Is 4S too much for a Hacker B8S?
skellyo
skellyo's Avatar
05.24.2007, 06:13 PM
I'm not that familiar with the BK19150 or Schulze 66ce, but you definitely need an LVC for Setup 1.
IMO, 2 - Trakpower's would be enough for any of those setups. And actually, 3s is more than you should put to an 8S.
neweuser
neweuser's Avatar
05.24.2007, 06:24 PM
Setup 1: stock
Option 3: ?
Set up one would need an LVC like previously said. You would better off sticking with NiMh IMO.
Set up two - assuming it's a car controller which I don't see on the website, it should be good up to 191amps? A 1930/5 is rated at 4180kv, not sure if that is loaded or not but it would bring your 1930/5 close to 60,000 rpm's on 4s if it's loaded kv rating, would also need an lvc.
the duals, dump'em IMO and get a single motor set up or take tha money and invest in lipo.
Gustav
Gustav's Avatar
05.24.2007, 06:32 PM
is it not a warrior 15020? 20 cells,150 amps.
is the 1930 a high-amp version or is it the standard version with the solder on the back.If it's the latter it can be reconfigured for a lower kv,that might just work out nicely for 4s.
