trakpower gold battery connector
blt4speed
trakpower gold battery connector -
06.19.2007, 09:30 PM
which connectors do i use with this battery? gold plugs? what size?
blt4speed
2
skellyo
06.19.2007, 09:36 PM
They're 4mm gold bullets.
skellyo
Find all posts by skellyo
3
blt4speed
06.19.2007, 11:12 PM
thank you
blt4speed
4
AAngel
06.19.2007, 11:31 PM
If you can, try to find that connectors with the split ends rather than the springy spinning thing on the male connector.
I don't know, maybe someone could articulate this better than I can right now.
AAngel
5
Serum
06.20.2007, 01:35 AM
then main leads are 4mm and the balancing tab is a 2mm plug.
Serum
Visit Serum's homepage!
Find all posts by Serum
6
Maxxman
06.20.2007, 01:41 PM
hi
i was wondering what size the schulze pins were.
http://www.finedesignrc.com/cars-trucks-esc.asp
i was just wondering if i could use them with the 3.5mm plugs in the store or not.
not trying to steal your thread but didn't see the need to start a new one thanks for any info
Maxxman
Find all posts by Maxxman
7
Serum
06.20.2007, 02:01 PM
4mm plugs
Serum
8
Maxxman
06.20.2007, 02:04 PM
alright thanks
guess i will have to replace them with 5.5mm plugs so i can use them with my quark
Maxxman
9
blt4speed
06.25.2007, 10:10 PM
what is the correct soldering method for the male bullets. my bullet connecors have half of the wire hole cylinder removed, is this normal?
thanks
blt4speed
10
06.25.2007, 11:15 PM
Some do. Makes it easier to use wires that are slightly larger than the hole. If not for that removed section and you were using larger wires, you'd have to shave some of the individual strands off to make them fit.
Visit BrianG's homepage!
Find all posts by BrianG
Linear Mode
Switch to Threaded Mode
5 : Excellent
4 : Good
3 : Average
2 : Bad
1 : Terrible
