Which Lehner Motor for my E-Revo???
Hickoryhead
RC Wanna BE
Hickoryhead's Avatar
Which Lehner Motor for my E-Revo??? - 08.29.2007, 05:29 PM
I have everything set up to finish my E-Revo. Everything is set except a motor. I have the MM ESC. I have 2 Maxamps 6000 mah 2s2p that will run in serious. I put a thread together in June were enough people said to use the 1940. But I read in the temporary forums were some use a 1950. Which should I buy? And how many turns 7, 8, or 9 should the motor have? I will be manly bashing but some racing locally. I want it fast yet durable and I will mess with gearing after I have the motor. (look for the thread later LOL) I hate to give my business to fine design but I read Mike's temporary thread about not carrying Lehners any more. If any one has a used one they want to part with let me know at cdmiche@sandia.gov.
Also I am using the Emaxx Tranny locked into 2nd. I read a thread from Brian today stating you should have a different slipper clutch. I have the stock one so what other slipper clutch would work? Or work better?
Thanks all!!!
skellyo
skellyo's Avatar
08.29.2007, 05:47 PM
If it were me, I'd look into a Neu 1515/1Y. A good number of folks are getting them to work well with the MM ESC with little to no cogging. I believe Mike himself evens runs a Neu on a MM.
jnev
jnev's Avatar
08.29.2007, 06:49 PM
I agree with what skellyo said. As for the slipper, you can try the strobe slipper from the RCM store, or the Robinson Racing one.
bdebde
That's All Folks!
bdebde's Avatar
08.29.2007, 09:02 PM
I would say a 1940/7 if running 4s. I have not tried a Neu with the MM, but I did try a Pletty (also 4 pole) with the MM. Even the occassional cogging was enough to piss me off. Try FDM, after all he is THE US distibutor for Lehner now. I know many on here have bad things to say about him, but I have had fantastic service with him.
Hickoryhead
RC Wanna BE
What is cogging exactly?
bdebde
That's All Folks!
bdebde's Avatar
08.29.2007, 09:22 PM
It is like a hesitation until the ESC finds the rotor position. It can sometimes cause a violent jerking if putting alot of throttle into it from a stand still (very bad).
Hickoryhead
RC Wanna BE
08.29.2007, 10:03 PM
I am a perfectionist. I had to buy a new radio because the stock one I had for my BL Stampede was jerking around the truck. I don't understand it but the ground was harder than the radio. LOL I don't want cogging to happen so I will stick with Lehner. I am not satified with the reports of the customer service from Lehner but its what I run in my other RC's. They work great for me. I hope Fine Design works out.
As a side note whats the difference between a 7 turn, 8 turn, or 9 turn motor? Say the motor is a 1940.
08.29.2007, 10:56 PM
Lower number equals lower wind. Lower wind means faster motor. Look at the kv number which is rpm per volt. You want to run your motor at a max of 35k rpms. This helps keep the heat down. Multiply the voltage battery you wish to use by the kv to get a motor rpm figure and try to stay below 35k rpm. Such as 14.8v x 2200kv = 32500 rpm = good. And then gear your truck to the speed you will want to run at. I gear all of my stuff to around 40mph cause it suits my drving style and area I play in.
E-Revolution
08.30.2007, 12:08 PM
I am looking new motor too, but I dont know what I take.. Is Lehner 22XX good motors ? I am looking good speed and torgue for my revo, I use 10 000mAh maxamps 7.4v LiPos (14.8v) . Some peoples says Neu 1515 1y, but its out of stock and I need my motor soon.
E-Maxx King
08.30.2007, 01:36 PM
Get a lehner 2230-2250 and hit 60 in that revo. You might have to run more voltage.
Hickoryhead
RC Wanna BE
08.30.2007, 05:25 PM
As in 60 MPH!?! That fast?
pb4ugo
08.30.2007, 08:15 PM
I have a 1950/7 turn I may part with. I am also in Southern Utah (Washington) so you won't have to pay shipping! Or if you just want to bash, let me know.
Hickoryhead
RC Wanna BE
08.30.2007, 08:43 PM
I am interested. Write me at cdmiche@sandia.gov. We can go from there.
E-Maxx King
08.30.2007, 11:59 PM
Ive read about people with this 22?? on 4-8s hitting 60 np. Just search lehner 2230, 2240, and 2250. O and there the same price as a 1950. But I dont know how well the revo will handle at those speeds.
coolrunnings
08.31.2007, 04:56 AM
My lehner 1950/6 is great on 4s in a 8.5 pound truck, before that it was a 1940/5 on 3s it rocked too.
